Esri maps through ArcMap
1541
11-15-2014 09:18 PM
AllisonRichards
I've imported layer files from Esri through ArcMap to use in my project and when I try to preform any functions with it (specifically Intersect in Model Builder) it gives an error. Is this because the layer file cannot be changed or is protected in some way?
Thanks! I'm a novice and appriciate any help/suggestions
XanderBakker
Esri Esteemed Contributor
Hi Allison,
Are the layer files you added to ArcMap referencing map services? In that case you cannot use them for analysis.
Kind regards, Xander
