Assign River Order Tool Fails with the follwoing:
Messages Executing: AssignRiverOrder NHDAreaLITTLECLIP RiverOrder Strahler # Start Time: Fri Nov 14 15:09:01 2014 Reading Input Parameters... System.TypeLoadException: Could not load type 'SplitP' from assembly 'ESRI.APWR.ApHydro, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null'. at ESRI.APWR.ArcHydroGPTools.ApConfigGP.AssignRiverOrder(ApProgworkMgr& pApProgMgr, ITable& pTable, ITable& pTableFS, String sRiverOrderField, RiverOrderType OrderType, String& NextDownFld, Int32& iMaxLoops, String FeatureIDFLD, ITrackCancel& trackCancel, IGPMessages& messages, String& sMsg) at ESRI.APWR.ArcHydroGPTools.AHAssignRiverOrder.Execute(IArray paramvalues, ITrackCancel trackcancel, IGPEnvironmentManager envMgr, IGPMessages message) in C:\Builds\HydroSolutions\10.2_ArcHydro\Sources\ArcHydroTools\src\ArcHydroGPTools\AHAssignRiverOrder.vb:line 386 Failed to execute (AssignRiverOrder). Failed at Fri Nov 14 15:09:02 2014 (Elapsed Time: 0.79 seconds)
On any varioation in size of NHD Flowlines that have successfully had TO/From Node and Hydro ID calculated. Suspecting split flow might be a problem, I get this same error even when running the tool on a small portion of the data with no split flow (e.g. 10 or 20 stream segments). Is this a new bug in this version of Arc Hydro? (yellow.esri.com - /archydro/archydro/Setup/10.2.x/10.2.0.85/ArcHydroTools10.2x64/
