Hi
I have used code derived from
Before quite well.
I have now created a new site, and am being good, using AMD and stuff. Yet it fails
This is the code I use, all in the function thingy of the initial require.
dojo.declare("myScripts.WatermarkLayer", DynamicMapServiceLayer, {
startExtent: new Extent({ xmin: 0, ymin: 0, xmax: 700000, ymax: 1300000, spatialReference: { wkid: 27700 } }),
//construct the layer
constructor: function (args) {
this.initialExtent = this.fullExtent = this.startExtent;
this.spatialReference = this.initialExtent.spatialReference;
dojo.mixin(this, args);
//set layer loaded property and fire onLoad event
this.loaded = true;
this.onLoad(this);
getImageUrl: function (extent, width, height, callback) {
try {
callback(this.url);
catch (ex) {
console.debug("Error getting Watermark image. " + ex.message);
_errorCallback: function (err) {
console.error(err.message);
wm = new myScripts.WatermarkLayer({ watermarkUrl: "Logo.png" })
wm.setOpacity(1);
map.addLayer(wm);
console.debug(wm)
console.debug(map)
It doesn't error - the console of the wm object shows what I would expect.
The console of the map object shows the lyaer added.
yet I get
GET http://dev/test/null 404 (Not Found)
Error - and I get this every time I zoom in or out, which indicates it isn't finding the watermark image
It's late on a Friday - if anyone thinks they can help I can put all code live somewhere next week
ACM
Slly me - the code wanted different parameters for tiled (which I used before) and dynamic. Dynamic only wanted url - leaving original post there as a pointer for others
