Cannot add lasd to map using python script in 10.2.2
1614
11-13-2014 02:03 PM
MarkNigrelli
I created a python script which creates a las dataset and adds it to the map. It worked fine in 10.1. I just installed 10.2.2 and now it gives me an error when I run the script. Is there something wrong with my script or did something change between 10.1 and 10.2.2 in terms of programmatically adding a lasd layer to a map?
Here's the offending subset of my script:
        arcpy.management.CreateLasDataset(InputLAS, OutputLASD, "NO_RECURSION", "", "", "", "RELATIVE_PATHS")
        Output_LASD_Layer = arcpy.CreateUniqueName("OutputLASD.lasd")
        arcpy.management.MakeLasDatasetLayer(OutputLASD, Output_LASD_Layer)
        addlayer = arcpy.mapping.Layer(Output_LASD_Layer)
        addlayer.name = Output_LASD_Layer_String
        arcpy.mapping.AddLayer(DataFrame, addlayer)
I get a value error:
  File "Script.py", line 138, in <module>
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\arcobjects\mixins.py", line 389, in __init__
    super(LayerMixin, self).__init__(lyrfile)
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\arcobjects\_base.py", line 47, in __init__
    for arg in args))
ValueError: Object: CreateObject Layer invalid data source
Tags (3)
ErikNilsson
Did you find a solution to add lasd-files to ArcMap? I have tried different approaches in 10.6 but haven't found a solution yet.
JoeBorgione
Eric-  given this original thread is 5 years old and refers to a version of software on which the sun has set, you may what to:
Start a new thread
and/or
Provide more details with respect to what you have tried, what are the desired results, and what are the actual results or error messages your are receiving.
