AnsweredAssumed Answered
Problem accessing feature layer on cloud (arcgis online)
Question asked by Jonathan1311 on Nov 13, 2014
Hi everyone,
I'm using the Access feature data in the cloud sample with my own service from ArcGis online, i have no particular error in my code and my basemap appear in the app. Can't find why my feature layer "monuments" doesn't appear. Any ideas? Thanks!
MainActivity
package com.arcgis.regeul_s;
import android.app.Activity;
import android.app.ProgressDialog;
import android.graphics.Color;
import android.os.AsyncTask;
import android.os.Bundle;
import android.view.LayoutInflater;
import android.view.Menu;
import android.view.MenuItem;
import android.view.ViewGroup;
import android.widget.TextView;
import com.esri.android.map.Callout;
import com.esri.android.map.GraphicsLayer;
import com.esri.android.map.Layer;
import com.esri.android.map.MapView;
import com.esri.android.map.ags.ArcGISFeatureLayer;
import com.esri.android.map.event.OnSingleTapListener;
import com.esri.android.map.event.OnStatusChangedListener;
import com.esri.core.geometry.Envelope;
import com.esri.core.geometry.Point;
import com.esri.core.map.Feature;
import com.esri.core.map.FeatureResult;
import com.esri.core.map.Graphic;
import com.esri.core.symbol.SimpleMarkerSymbol;
import com.esri.core.tasks.query.QueryParameters;
import com.esri.core.tasks.query.QueryTask;
public class REGEUL_SActivity extends Activity {
    MapView mMapView;
    private ArcGISFeatureLayer mFeatureLayer;
    GraphicsLayer mGraphicsLayer;
    private Callout mCallout;
    private Graphic mIdentifiedGraphic;
    private int mCalloutStyle;
    private ViewGroup mCalloutContent;
    boolean mIsMapLoaded;
    private String mFeatureServiceURL;
    ProgressDialog progress;
    // The query params switching menu items.
    MenuItem mQueryMdMenuItem = null;
    MenuItem mQueryPkMenuItem = null;
    MenuItem mQueryAuMenuItem = null;
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.main);
       // Retrieve the map and initial extent from XML layout
        mMapView = (MapView) findViewById(R.id.map);
        // Get the feature service URL from values->strings.xml
        mFeatureServiceURL = this.getResources().getString(R.string.featureServiceURL);
        // Add Feature layer to the MapView
        mFeatureLayer = new ArcGISFeatureLayer(mFeatureServiceURL, ArcGISFeatureLayer.MODE.ONDEMAND);
        mMapView.addLayer(mFeatureLayer);
        // Add Graphics layer to the MapView
        mGraphicsLayer = new GraphicsLayer();
        mMapView.addLayer(mGraphicsLayer);
        // Set the Esri logo to be visible, and enable map to wrap around date line.
        mMapView.setEsriLogoVisible(true);
        mMapView.enableWrapAround(true);
        // Get the MapView's callout from xml->identify_calloutstyle.xml
        mCalloutStyle = R.xml.identify_calloutstyle;
        LayoutInflater inflater = getLayoutInflater();
        mCallout = mMapView.getCallout();
        // Get the layout for the Callout from
        // layout->identify_callout_content.xml
        mCalloutContent = (ViewGroup) inflater.inflate(R.layout.identify_callout_content, null);
        mCallout.setContent(mCalloutContent);
        mMapView.setOnStatusChangedListener(new OnStatusChangedListener() {
          private static final long serialVersionUID = 1L;
            public void onStatusChanged(Object source, STATUS status) {
                // Check to see if map has successfully loaded
                if ((source == mMapView) && (status == STATUS.INITIALIZED)) {
                    // Set the flag to true
                    mIsMapLoaded = true;
        mMapView.setOnSingleTapListener(new OnSingleTapListener() {
            public void onSingleTap(float x, float y) {
                if (mIsMapLoaded) {
                    // If map is initialized and Single tap is registered on screen
                    // identify the location selected
                    identifyLocation(x, y);
     * Takes in the screen location of the point to identify the feature on map.
     * @param x
     *          x co-ordinate of point
     * @param y
     *          y co-ordinate of point
    void identifyLocation(float x, float y) {
        // Hide the callout, if the callout from previous tap is still showing
        // on map
        if (mCallout.isShowing()) {
            mCallout.hide();
        // Find out if the user tapped on a feature
        SearchForFeature(x, y);
        // If the user tapped on a feature, then display information regarding
        // the feature in the callout
        if (mIdentifiedGraphic != null) {
            Point mapPoint = mMapView.toMapPoint(x, y);
            // Show Callout
            ShowCallout(mCallout, mIdentifiedGraphic, mapPoint);
     * Sets the value of mIdentifiedGraphic to the Graphic present on the
     * location of screen tap
     * @param x
     * @param y
    private void SearchForFeature(float x, float y) {
        if (mapPoint != null) {
            for (Layer layer : mMapView.getLayers()) {
                if (layer == null)
                    continue;
                if (layer instanceof ArcGISFeatureLayer) {
                    ArcGISFeatureLayer fLayer = (ArcGISFeatureLayer) layer;
                    // Get the Graphic at location x,y
                    mIdentifiedGraphic = GetFeature(fLayer, x, y);
     * Returns the Graphic present the location of screen tap
     * @param fLayer
     *          ArcGISFeatureLayer to get graphics ids
     * @param x
     * @param y
     * @return Graphic at location x,y
    private Graphic GetFeature(ArcGISFeatureLayer fLayer, float x, float y) {
        // Get the graphics near the Point.
        int[] ids = fLayer.getGraphicIDs(x, y, 10, 1);
        if (ids == null || ids.length == 0) {
            return null;
        return fLayer.getGraphic(ids[0]);
     * Shows the Attribute values for the Graphic in the Callout
     * @param calloutView a callout to show
     * @param graphic selected graphic
     * @param mapPoint point to show callout on map
    private void ShowCallout(Callout calloutView, Graphic graphic, Point mapPoint) {
        // Get the values of attributes for the Graphic
        String matricule = (String) graphic.getAttributeValue("Matricule").toString();
        String mater = (String) graphic.getAttributeValue("Materialisation").toString();
        String latitude = graphic.getAttributeValue("Latitude").toString();
        String longitude = graphic.getAttributeValue("Longitude").toString();
        String altitude = graphic.getAttributeValue("Altitude").toString();
        String x_utm19 = graphic.getAttributeValue("X_UTM19").toString();
        String y_utm19 = graphic.getAttributeValue("Y_UTM19").toString();
        String x_mtm7 = graphic.getAttributeValue("X_MTM7").toString();
        String y_mtm7 = graphic.getAttributeValue("Y_MTM7").toString();
        String hauteur = graphic.getAttributeValue("Hauteur").toString();
        String ondul = graphic.getAttributeValue("Ondulation").toString();
        String xi = graphic.getAttributeValue("Xi").toString();
        String eta = graphic.getAttributeValue("Eta").toString();
        String prec_n = graphic.getAttributeValue("Prec_N").toString();
        String prec_e = graphic.getAttributeValue("Prec_E").toString();
        String prec_v = graphic.getAttributeValue("Prec_V").toString();
        String tech_mes = graphic.getAttributeValue("Tech_mesure").toString();
        String comment = graphic.getAttributeValue("Commentaire").toString();
        // Set callout properties
        calloutView.setCoordinates(mapPoint);
        calloutView.setStyle(mCalloutStyle);
        calloutView.setMaxWidth(325);
        // Compose the string to display the results
        StringBuilder pointMatriculeName = new StringBuilder();
        pointMatriculeName.append("Matricule: ");
        pointMatriculeName.append(matricule);
        TextView calloutTextLine1 = (TextView) findViewById(R.id.Matricule);
        calloutTextLine1.setText(pointMatriculeName);
        StringBuilder pointMaterName = new StringBuilder();
        pointMaterName.append("Matérisalisation: ");
        pointMaterName.append(mater);
        TextView calloutTextLine2 = (TextView) findViewById(R.id.Mater);
        calloutTextLine2.setText(pointMaterName);
        StringBuilder pointLatitudeName = new StringBuilder();
        pointLatitudeName.append("Latitude: ");
        pointLatitudeName.append(latitude);
        TextView calloutTextLine3 = (TextView) findViewById(R.id.Latitude);
        calloutTextLine3.setText(pointLatitudeName);
        StringBuilder pointLongitudeName = new StringBuilder();
        pointLongitudeName.append("Longitude: ");
        pointLongitudeName.append(longitude);
        TextView calloutTextLine4 = (TextView) findViewById(R.id.Longitude);
        calloutTextLine4.setText(pointLongitudeName);
        StringBuilder pointAltitudeName = new StringBuilder();
        pointAltitudeName.append("Altitude: ");
        pointAltitudeName.append(altitude);
        TextView calloutTextLine5 = (TextView) findViewById(R.id.Altitude);
        calloutTextLine5.setText(pointAltitudeName);
        StringBuilder pointX_UTM19Name = new StringBuilder();
        pointX_UTM19Name.append("X_UTM19: ");
        pointX_UTM19Name.append(x_utm19);
        TextView calloutTextLine6 = (TextView) findViewById(R.id.X_UTM19);
        calloutTextLine6.setText(pointX_UTM19Name);
        StringBuilder pointY_UTM19Name = new StringBuilder();
        pointY_UTM19Name.append("Y_UTM19: ");
        pointY_UTM19Name.append(y_utm19);
        TextView calloutTextLine7 = (TextView) findViewById(R.id.Y_UTM19);
        calloutTextLine7.setText(pointY_UTM19Name);
        StringBuilder pointX_MTM7Name = new StringBuilder();
        pointX_MTM7Name.append("X_MTM7: ");
        pointX_MTM7Name.append(x_mtm7);
        TextView calloutTextLine8 = (TextView) findViewById(R.id.X_MTM7);
        calloutTextLine8.setText(pointX_MTM7Name);
        StringBuilder pointY_MTM7Name = new StringBuilder();
        pointY_MTM7Name.append("Y_MTM7: ");
        pointY_MTM7Name.append(y_mtm7);
        TextView calloutTextLine9 = (TextView) findViewById(R.id.Y_MTM7);
        calloutTextLine9.setText(pointY_MTM7Name);
        StringBuilder pointHauteurName = new StringBuilder();
        pointHauteurName.append("Hauteur: ");
        pointHauteurName.append(hauteur);
        TextView calloutTextLine10 = (TextView) findViewById(R.id.Hauteur);
        calloutTextLine10.setText(pointHauteurName);
        StringBuilder pointOndulationName = new StringBuilder();
        pointOndulationName.append("Ondulation: ");
        pointOndulationName.append(ondul);
        TextView calloutTextLine11 = (TextView) findViewById(R.id.Ondulation);
        calloutTextLine11.setText(pointOndulationName);
        StringBuilder pointXiName = new StringBuilder();
        pointXiName.append("Xi: ");
        pointXiName.append(xi);
        TextView calloutTextLine12 = (TextView) findViewById(R.id.Xi);
        calloutTextLine12.setText(pointXiName);
        StringBuilder pointEtaName = new StringBuilder();
        pointEtaName.append("Eta: ");
        pointEtaName.append(eta);
        TextView calloutTextLine13 = (TextView) findViewById(R.id.Eta);
        calloutTextLine13.setText(pointEtaName);
        StringBuilder pointPrec_NName = new StringBuilder();
        pointPrec_NName.append("Prec_N: ");
        pointPrec_NName.append(prec_n);
        TextView calloutTextLine14 = (TextView) findViewById(R.id.Prec_N);
        calloutTextLine14.setText(pointPrec_NName);
        StringBuilder pointPrec_EName = new StringBuilder();
        pointPrec_EName.append("Prec_E: ");
        pointPrec_EName.append(prec_e);
        TextView calloutTextLine15 = (TextView) findViewById(R.id.Prec_E);
        calloutTextLine15.setText(pointPrec_EName);
        StringBuilder pointPrec_VName = new StringBuilder();
        pointPrec_VName.append("Prec_V: ");
        pointPrec_VName.append(prec_v);
        TextView calloutTextLine16 = (TextView) findViewById(R.id.Prec_V);
        calloutTextLine16.setText(pointPrec_VName);
        StringBuilder pointTech_mesName = new StringBuilder();
        pointTech_mesName.append("tech_mes: ");
        pointTech_mesName.append(tech_mes);
        TextView calloutTextLine17 = (TextView) findViewById(R.id.Tech_mes);
        calloutTextLine17.setText(pointTech_mesName);
        StringBuilder pointCommentName = new StringBuilder();
        pointCommentName.append("Comment: ");
        pointCommentName.append(comment);
        TextView calloutTextLine18 = (TextView) findViewById(R.id.Comment);
        calloutTextLine18.setText(pointCommentName);
        calloutView.setContent(mCalloutContent);
        calloutView.show();
     * Run the query task on the feature layer and put the result on the map.
    private class QueryFeatureLayer extends AsyncTask<String, Void, FeatureResult> {
        // default constructor
        public QueryFeatureLayer() {
        @Override
        protected void onPreExecute() {
            progress = ProgressDialog.show(REGEUL_SActivity.this, "", "Please wait....query task is executing");
        @Override
        protected FeatureResult doInBackground(String... params) {
            String whereClause = "COUNTRY='" + params[0] + "'";
            // Define a new query and set parameters
            QueryParameters mParams = new QueryParameters();
            mParams.setWhere(whereClause);
            mParams.setReturnGeometry(true);
            // Define the new instance of QueryTask
            QueryTask queryTask = new QueryTask(mFeatureServiceURL);
            FeatureResult results;
            try {
                // run the querytask
                results = queryTask.execute(mParams);
                return results;
            } catch (Exception e) {
                e.printStackTrace();
            return null;
        @Override
        protected void onPostExecute(FeatureResult results) {
            // Remove the result from previously run query task
            mGraphicsLayer.removeAll();
            // Define a new marker symbol for the result graphics
            SimpleMarkerSymbol sms = new SimpleMarkerSymbol(Color.BLUE, 10, SimpleMarkerSymbol.STYLE.CIRCLE);
            // Envelope to focus on the map extent on the results
            Envelope extent = new Envelope();
            // iterate through results
            for (Object element : results) {
                // if object is feature cast to feature
                if (element instanceof Feature) {
                    Feature feature = (Feature) element;
                    // convert feature to graphic
                    Graphic graphic = new Graphic(feature.getGeometry(), sms, feature.getAttributes());
                    // merge extent with point
                    extent.merge((Point)graphic.getGeometry());
                    // add it to the layer
                    mGraphicsLayer.addGraphic(graphic);
            // Set the map extent to the envelope containing the result graphics
            mMapView.setExtent(extent, 100);
            // Disable the progress dialog
            progress.dismiss();
    @Override
    public boolean onCreateOptionsMenu(Menu menu) {
        // Inflate the menu; this adds items to the action bar if it is present.
        getMenuInflater().inflate(R.menu.main_menu, menu);
        // Get the query params menu items.
        mQueryMdMenuItem = menu.getItem(0);
        mQueryPkMenuItem = menu.getItem(1);
        mQueryAuMenuItem = menu.getItem(2);
        return true;
    @Override
    public boolean onOptionsItemSelected(MenuItem item) {
        // Handle menu item selection.
        switch (item.getItemId()) {
            case R.id.Query_MD:
                mQueryMdMenuItem.setChecked(true);
                new QueryFeatureLayer().execute("Medaillon");
                return true;
            case R.id.Query_PK:
                mQueryPkMenuItem.setChecked(true);
                new QueryFeatureLayer().execute("Pk");
                return true;
            case R.id.Query_AU:
                mQueryAuMenuItem.setChecked(true);
                new QueryFeatureLayer().execute("Autre");
                return true;
            default:
                return super.onOptionsItemSelected(item);
    @Override
    protected void onPause() {
        super.onPause();
        mMapView.pause();
    @Override
    protected void onResume() {
        super.onResume();
        mMapView.unpause();
Strings
<?xml version="1.0" encoding="utf-8"?>
<resources>
    <string name="app_name">REGEUL_S</string>
    <string name="spinTitle">Query Customer Data:</string>
   <string name="featureServiceURL">http://http://services3.arcgis.com/D7xw8Tli8HKiA30u/ArcGIS/rest/services/monuments/FeatureServer/0</string>
    <!-- query parameters -->
    <string name="Query_md">Medaillon</string>
    <string name="Query_pk">PK</string>
    <string name="Query_au">Autre</string>
</resources>
Outcomes
