How do I get my LocateButton widget to work with our TiledMapService?
2533
11-12-2014 09:43 AM
ChrisSergent
Regular Contributor III
I am receiving the following error when I click on the LocateButton widget: Map: Geometry (wkid: 4326) cannot be converted to spatial reference of the map (wkid: 3435)
The url for my application is at: Decatur GIS Template
What do I need to change for the locate button to work?
Here is my code:
<!DOCTYPE html>
<html>
    <head>
        <title>Decatur GIS Template</title>
        <meta http-equiv="content-type" content="text/html; charset=utf-8">
        <meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
        <style>
            html, body, #mapDiv
                padding:0;
                margin:0;
                height:100%;
            #HomeButton
                position: absolute;
                top: 250px;
                left: 20px;
                z-index: 50;
            #LocateButton
              position: absolute;
              top: 300px;
              left: 20px;
              z-index: 50;
        </style>
        <script src="http://js.arcgis.com/3.11/"></script>
        <script>
            var map;
            require(["esri/map",
                    "esri/dijit/HomeButton", "esri/dijit/LocateButton",
                    "esri/layers/ArcGISTiledMapServiceLayer",
                    "esri/layers/ArcGISDynamicMapServiceLayer",
                    "dojo/dom", "dojo/on", "dojo/parser",
                    "esri/geometry/Extent", "dojo/domReady!"], function (Map, HomeButton, LocateButton, Tiled, ArcGISDynamicMapServiceLayer, dom, on, parser, Extent
                // set custom extent
                var initialExtent = new Extent({ "xmin": 777229.03, "ymin": 1133467.92, "xmax": 848340.14, "ymax": 1185634.58, "spatialReference": { "wkid": 3435}});
                map = new Map("mapDiv", {
                    showAttribution: false,
                    sliderStyle: "large",
                    extent:initialExtent
                    // add imagery
                    var tiled = new Tiled("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
                    map.addLayer(tiled);
                    // add operational layer
                    var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", { "opacity": 0.5 });
                    map.addLayer(operationalLayer);
                    // add home button to get full extent
                    var home = new HomeButton({
                        map: map
                    }, "HomeButton");
                    home.startup();
                    // add geolocate button to find the location of the current user
                    geoLocate = new LocateButton({
                        map: map,
                        highlightLocation:true
                    }, "LocateButton");
                    geoLocate.startup();
        </script>
    </head>
    <body class="soria">
        <div id="mapDiv">
            <div id="HomeButton"></div>
            <div id="LocateButton"></div>
        </div>
    </body>
</html>
Tags (1)
DaveTimmins
Occasional Contributor II
You just need to set the default geometry service url in the esriConfig
So define
define([
    'esri/config',
    'esri/tasks/GeometryService',
    function (
      esriConfig,
      GeometryService
and then before you initialise your LocateButton dijit
esriConfig.defaults.geometryService = new GeometryService(url);
DaveTimmins
So define
define([
    'esri/config',
    function (
      esriConfig,
      GeometryService
ChrisSergent
I updated in my AMD code. It works! Thanks Dave.
Here is my updated code for anyone that needs it:
<!DOCTYPE html>
<html>
    <head>
        <style>
            html, body, #mapDiv
                padding:0;
                margin:0;
                height:100%;
            #HomeButton
                position: absolute;
                top: 250px;
                left: 20px;
                z-index: 50;
            #LocateButton
              position: absolute;
              top: 300px;
              left: 20px;
              z-index: 50;
        </style>
        <script>
            var map;
            require(["esri/map", "esri/config",
                    "esri/tasks/GeometryService",
                    "esri/geometry/Extent", "dojo/domReady!"], function (Map, esriConfig, HomeButton, LocateButton, Tiled, ArcGISDynamicMapServiceLayer, GeometryService, dom, on, parser, Extent
                        var initialExtent = new Extent({ "xmin": 777229.03, "ymin": 1133467.92, "xmax": 848340.14, "ymax": 1185634.58, "spatialReference": { "wkid": 3435} });
                            extent: initialExtent
                        // add imagery
                        // declare geometry service
                        esriConfig.defaults.geometryService = new GeometryService("http://maps.decaturil.gov/arcgis/rest/services/Utilities/Geometry/GeometryServer");
                            map: map
                        }, "HomeButton");
                        home.startup();
                            map: map,
                            highlightLocation: true
                        }, "LocateButton");
        </script>
    </head>
        <div id="mapDiv">
        </div>
    </body>
</html>
