Attaching Photos
2441
11-04-2014 07:21 AM
PeterGottfried
I have ArcMap Basic.  I want to attach non-geotagged photos to a point shapefile.  each point will have 1-4 photos per point.  How can i do this?
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Peter,
If you import the shapefile into a File Geodatabase, you can enable attachments.
PeterGottfried
I don't think that feature is available with ArcMap Basic
JakeSkinner
Peter, you are correct, enabling attachments is not available with Basic.  Another option you have is to create a new field of type 'Raster' and add the image to this field.  See the following link:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Note:  the data must be a geodatabase feature class in order to create a field of type Raster
