Missing Styles and Color Ramp, Please Help
9072
11-03-2014 08:53 AM
BenSandiford
Hello the other day in Arc Map all my style files and Color Ramps have disappeared and they cannot be re enabled under style manager. I have tried a number of ways to restore them but none have worked.
1. Re-registered dao360.dll
2. Repaired ArcMap using the installer
3. Deleted and/or renamed ArcGIS profile at C:users\(profile)\appdata\roaming\
4.  Reset the registry:
Open ArcMapAdvancedUtility (from C:\Program
Files\ArcGIS\Desktop10.2\Utilities)
Click "Reset all values to default"
Then click "Reread current settings" and close the utility.
None of them have had the slightest effect, the style files are at the correct location on my hard drive if that's helpful.
AndySmith
Hi Ben,
This is similar to an old thread: ArcMap 10 - No Color Ramp, Scale Bars and North Arrows
Please ensure that you have at least one style selected: Why are ArcGIS 10.2 Color Ramps missing? - Geographic Information Systems Stack Exchange
You should also check that the Esri fonts are still installed under: C:\Windows\Fonts. If they are not, make a copy of the Esri .ttf files and reimport them.
