Cannot save my domain in my field properties!
5006
11-01-2014 05:13 PM
CalvinMcCarron
I'm having an issue in ArcCatalog where my feature class does not want to save the domain I created for it in the database. Every time I go into the field properties in my field within my feature class I try to save domain I want to use and it does not work.
A few things I tried:
  • Recreating the database from scratch.
  • Trying a different naming convention.
None of these worked unfortunately.
Does anyone have a solution?
Thanks.
Here is my domain:
Here is my fields in my feature class:
LuciHawkins
Occasional Contributor III
When you click in the white box to the right of "Domain" in the "Field Properties" area, the domain "bench_type" is available and you select it.  Then when you click "Apply" the changes are not saved?
Luci
JoeFlannery
Have you tried the Assign Domain To Field (Data Management) tool?
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
