I need code to convert a point shapefile with a designated attribute containing Z (height) values to a 3D Shapefile.
I found exact sample I need here (searching 'points 2D to 3D'): ArcObjects 10 Cross-platform C++ SDK Help
Problem is that this sample is C++ and I need it in C#. Down in the sample topic it says there's a link to "Download the file for other languages". However, if I download those "other" files, I still get C++ files only.
I tried to use C++ sample, but I can't compile it, because it included Arcsdk.h which I don't have (I guess).
I am new in Programming, maybe there is possible to easily rewrite C++ code into C# or I will face a lot of problems related to '#Include' commands?
I need this code badly, must find a solution for it.
I hope someone can help
Just to clarify, you want to take a point and attach a Z value onto it using a field from the attributes table?
Yes. For instance, I have 2x shape files and I want to use Z value from
attribute table (shape file 2) to be used into Shape file 1 to add those
values as Z.
2014-11-03 22:10 GMT+02:00 Cody Scott <geonet@esri.com>:
GeoNet
<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo8h7SGfRSMkw-2FpvHGF9-2FW3rK-2Bvs1kL9-2FnG6jjf2NZhrLDz0M-2BrY-2By9IaziQEKVk3Hg-3D-3D_K598lVVgtYdkNo-2FTZAyPYaJOTD-2B3qCDmSWqtvZf8Z2djXDYodfFdHfrnJHC84uQotH0hG5kCCOmX8H-2FOELCiDlnqvJrn3ajtDw-2BGyJKtxvNVa2bls8Zr2K3SuM5Yj-2F2R7H97EG4ANUndCqclDigplemU6-2BFt11l2ENDSpaFYg3QnOhyHZ4-2BmHQ6t4TrHOz-2FTjMaJ4Y8EoNBTgvM33NU8VGRZy5lHlFEKcbZdsLOFRt8f9DcmWcLuCxVRUXtmmh3F42hExHTc3g7LYxXHSg0DumbvJ-2FclKEGoCNgA1SReEgONapVoIJ8sqHt4r2KewKjxN8bvPMijm9p61PimFLXpAA-3D-3D> Points
2D to 3D
reply from Cody Scott
<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo7A4BXwO9PY1WvQ5cXCtK49Hi-2BVXx61GYOapgR3aES7eqlSkBNJmD0QjOy2LlCW3E8ePqyTDd7EReUXI-2BtC1ciM-3D_K598lVVgtYdkNo-2FTZAyPYaJOTD-2B3qCDmSWqtvZf8Z2djXDYodfFdHfrnJHC84uQotH0hG5kCCOmX8H-2FOELCiDlnqvJrn3ajtDw-2BGyJKtxvNVa2bls8Zr2K3SuM5Yj-2F2R7H97EG4ANUndCqclDigpldNDrpmvG2PuaB6a-2F1v5yCagghglTqPjqRqyMd5eZaG0jRPaMT6JAYifBShm5-2BAi7b1fejFNefxYR-2BIPljA3vrsuU24yuGxPE5FlKylgE3ZlhyrtyP9v8VfwxYsKtd7ICp6q2LA1v2JzizudsTBPdbphNiq4KD5J8letf-2BqSLM9FAl7PfjXLyEytZF1pgqlhug-3D-3D>
in ArcObjects SDK - View the full discussion
<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo0VQjeJBYpG9HGC8QZBT-2FEwxiePNxSLpF8gwlWlU2c2Td6RmXkL-2BNvfBq5z6Nn32hWK0rNbZCGl2uluIdjg5WM0-3D_K598lVVgtYdkNo-2FTZAyPYaJOTD-2B3qCDmSWqtvZf8Z2djXDYodfFdHfrnJHC84uQotH0hG5kCCOmX8H-2FOELCiDlnqvJrn3ajtDw-2BGyJKtxvNVa2bls8Zr2K3SuM5Yj-2F2R7H97EG4ANUndCqclDigplWLqVy-2BvSwZtE0cp3UuUcYl0uYT91nUttxdsNjSfBKhKnmr-2FVY49dlxpM26tH57uLq4Cb0tL5OsZ3r-2FgCEzPk8bXx-2BKeCFeLboOqBIwITH2eXnnquRhdt6ERdfMsB09oaL-2FZxPg8NWc76EHTSCBJfXQ-2FUQLjMeLGXrRLY5SUu7dyWt1CieXNvuQEPQnKy3AeMQ-3D-3D>
Ok.
One more question. Is there anything connecting the points from feature A to feature B?
some sort of relationship field, etc.
No, there's no connecton
So how do they relate to each other...?
