Could not find the main class:com.zerog.lax.LAX
8617
10-31-2014 06:59 AM
JoneWu
Hi, I meet a problem for a few days. I used a ArcGIS Server 10.1 to setup on RedHat Enterprise 64bit. CheckPackagePrerequisites works all right. But when I run the setup, the screen shows:
Launching installer...
Exception in thread "main" java.lang.NoClassDefFoundError:com/zerog/lax/LAX
Caused by: java.lang.ClassNotFoundException:com.zerog.lax.LAX
             at  java.net.URLClassLoader$1.run(Unknown Source)
             at  java.security.AccessController.doPrivileged(Native Method)
             at java.net.URLClassLoader.findClass(Unknown Source)
Could not find the main class:com.zerog.lax.LAX. Program will exit.
At first, I thought it was java runtime's problem, so I install java version "1.7.0_71". But it still didn't work. Has anyone meet the same problem? How to deal with it?
Tags (1)
GriffinMorgan1
The installer uses a bundled version of Java so updating your system Java runtime won't help. What version of RedHat are you using?
Sincerely,
Griffin D. Morgan
esri UNIX Install Programmer
JoneWu
RedHat Enterprise 6.4, 64bit. Is the installer's problem? I used the ArcGIS_Server_Ent_Linux_101_129046.iso, MD5: 2CD9E00CC908C86548196ABA57A4065B
GriffinMorgan1
I believe the problem is that you are missing 32-bit glibc libraries. While ArcGIS Server itself is a 64-bit application, the installer uses some components which require 32-bit glibc.
