So I have some street data where a field I am searching on has some values that look like
135' S/O Main St
This is causing problems when trying to search for these with the ArcGIS REST API.
I've tried using the following
135%27 S/O Main St
But that doesn't work either. I know they are there because I can search on the ID and they come back in results, but I need to search on the actual value.
Any tips? Anyone run into this before?
Thans.
So there doesn't seem to be an easy way around this, even trying to do the query directly in ArcMap.
What I ended up doing, since I am using this in a backend service anyway was to check if a single quote was in the request, create a substring up the index location of the single quote, do a LIKE request with a wildcard and from the results, find the one that matches the original request.
It would look something like this in .NET.
string m_search = search;
bool hasQuote = search.Contains("'");
if (hasQuote == true)
m_search = search.Substring(0, search.IndexOf("'"));
// do API request and get response
// string where = "where=FIELDNAME LIKE '" + m_search + "%'";
var features = response["features"];
List<object> list = new List<object>();
for (int i = 0; i < features.Length; i++)
var feat = features;
var attr = feat["attributes"];
if (attr["FIELDNAME"] == search)
list.Add(attr);
return list;
It seems to be working ok so far and not's noticeably slower in my current queries.
In case anyone else comes across this problem, that's how I figured it out.
