An error was encountered while synchronizing with the config store
9363
8
10-28-2014 09:18 AM
Sravan_KumarUddarraju
I do have Geodata service and couple of mapservice in ArcGIS Server. There is no activities (sync) going on server, but still see the following error in ArcGIS Server logs. Any idea why am I getting this error? We don't have clusters, using only one ArcGIS Server 10.2.2 machine.
Error:An error was encountered while synchronizing with the config store. Failed to synchronize machine 'XXXXX' with the site. Failed to update the identity store configuration. Failed to refresh the identity store configuration. RemoteException occurred in server thread; nested exception is: java.rmi.UnmarshalException: error unmarshalling arguments; nested exception is: java.lang.ClassNotFoundException: com.esri.arcgis.discovery.servicelib.ServerContext
Sravan
DavidFlack
New Contributor III
Sravan, I am seeing an identical error on my 10.2.2 installation that uses the 10.0 SQL Server User and Role Stores..  What kind of security store are you using?
I'm working with ESRI support and will let you know if I find anything.. Have you been able to find out more about this?
Dave
DavidFlack
New Contributor III
Dave
We are using asp.net membership and role provider for SQL Server (10.50.4000). I can't explain what was causing this error (I think something was wrong with Identity store Json config properties) , but I have followed the documentation and reconfigured Identity store (configured to membership database)  and it did work for me.
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Sravan
DavidFlack
New Contributor III
I spent many hours with ESRI support on this. They were truly stumped and recommended a clean installation of ArcGIS Server and the WebAdaptor.
After I reinstalled 10.2.2, I was left the same issue. After removing 10.2.2 again, I tried installing Server 10.2.1 and now it seems to work normally.
JanineLatham
Has there been any response from ESRI on this issue for 10.2.2? We also are using a custom identity store, asp.net framework with SQL Server backend. We were using this custom identity store on 10.1 without seeing this issue. Thanks
KrisFuller
David, or anyone in this forum, have you heard anything back from ESRI regarding this issue? I also use a SQL Server Identity Store and am getting the exact same error message.
Any information on resolving this issue is much appreciated.
DavidFlack
New Contributor III
Kris, after a lot of hours working with tech support, we finally gave up on 10.2.2 and installed 10.2.1.  Since then the problem completely disappeared. I believe ESRI found a bug and has it fixed at 10.3, but I'm not certain of it.  I think the bug is this one:
NIM102779
When an ASP.NET customer provider is configured with Server, changing Server security
protocol produces severe errors in Server log at every minute.
KrisFuller
Thanks for the response David. NIM102779 does sound like the bug we are experiencing. We are going to install 10.3 on a dev server next week and will be able to test it out. I will post my results.
by Anonymous User
Not applicable
I'm getting this same error on a 4 machine server site using ArcGIS 10.3.1 (with all patches applied). Has anyone found a solution?
