arcgis server error 00099: Layer has a join with an unsupported data source
2508
10-28-2014 12:45 PM
ShaningYu
I tried to publish a dynamically generated layer as a map service.  This dynamic layer is generated through a ModelBuilder that consists of a Add Join tool.  In the map service publishing, I received the error: 00099: Layer has a join with an unsupported data source.  I believe that that is due to the use of an In-Memory FC (unsupported data source).  Through google, I could not find any discussion to avoid/eliminate this problem.  Do you know how?  Appreciate if you can share your experience.
Tags (1)
SusanJones
Occasional Contributor II
Is the data source registered with ArcGIS Server?
Does the data source contain a unique key field that can double as a ObjectId key?
Consider using the the Make Query Table tool in your model/python script before calling the Add Join tool
SusanJones
ShaningYu
Susan:  Wonderful!  Per your advisory, I substituted the Add Join tool by the Make Query Table tool.  Then, it went through in publishing it as a map service.  Thanks.
