I have a bug where i have problems opening up Arcmap. The Splash screen goes through the process of opening everything up. But when it gets to the "Finalizing Startup" at the end no window opens. And no error message appears.
It happens whether i open up a new MXD or an existing MXD
To fix it i have to remove the registry entry for ArcMap and it works again. But the problem seems to occur a few days later and i have to do it again.
I am wondering if anyone else has had this problem before and whether there is a permanent fix.
Rod
