Hover over feature layer does not work!
2707
10-27-2014 04:05 AM
IsraAlhamood
<!DOCTYPE html>
<html class="no-js dj_ie dj_ie9 dj_contentbox" lang="en">
<head>
<meta charset="UTF-8" />
<meta content="IE=edge,chrome=1" http-equiv="X-UA-Compatible">
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
<meta content="Mohammed Zainuddin" name="author" />
<title>U-Drive Locator</title>
<link href="css/normalize.css" rel="stylesheet" type="text/css" />
<link href="css/style.css" rel="stylesheet" type="text/css" />
<link rel="stylesheet" href="esri.css">
<!--[if IE]><script src="http://html5shiv.googlecode.com/svn/trunk/html5.js"></script><![endif]-->
<script type="text/javascript" src="js/modernizr.custom.js"></script>
<script type="text/javascript" src="js/jquery.min.js" ></script>
<script type="text/javascript" src="js/jquery-ui.min.js" ></script>
<script type="text/javascript" src="js/vendors/jquery.slimscroll.min.js"></script>
<script type="text/javascript" src="js/jquery.fullPage.js"></script>
<script type="text/javascript" src="js/cssrefresh.js"></script>
<!--[if IE]>
<script type="text/javascript">
  var console = { log: function() {} };
</script>
<![endif]-->
<script src="js/gsitu-head2.js"></script>
<script src="js/classie.js"></script>
<script src="js/gnmenu.js"></script>
<script src="js/init.js"></script>
<!-- Esri  -->
<link href="esri.css" rel="stylesheet">
<script src="identi1.dat"></script>
<script type="text/javascript"> var djConfig = { parseOnLoad: true };</script>
<script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.1" type="text/javascript">
</script>
<script type="text/javascript"> dojo.require("dijit.layout.BorderContainer");
  dojo.require("dijit.layout.ContentPane");
  dojo.require("esri.map");
  dojo.require("esri.layers.FeatureLayer");
  dojo.require("esri.dijit.AttributeInspector");
  dojo.require("esri.tasks.query");
  dojo.require("dojo.number");
  dojo.require("dojo/on");
  var map;
  var extent = new esri.geometry.Extent({"xmin" :5564986.97 ,"ymin" : 3029612.93  ,"xmax": 5599383.63 ,"ymax": 3052544.04, "spatialReference":{"wkid": 102100}});
  function init()
   map = new esri.Map("mapDiv");
   var basemap = new esri.layers.ArcGISTiledMapServiceLayer("basemapLink");
   map.addLayer(basemap);
   var template1 = "This is Template 1";
   var template2 =  "This is Template 2";
   var template3 =  "This is Template 3";
   var infoTemplate = new esri.InfoTemplate();
   infoTemplate.setTitle("<b>${BUILDING_NO}</b>");
   infoTemplate.setContent("default");
   map.infoWindow.resize(450,305);
   var featureLayer = new esri.layers.FeatureLayer("featureLayerLink", {
        mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
         outFields: ["*"],
         infoTemplate: infoTemplate
      featureLayer.on("mouse-over",function (event) {
                //map.graphics.clear();  //use the maps graphics layer as the highlight layer
                var graphic = event.graphic;
                if (graphic.attributes.OBJECTID == 1) {
                   infoTemplate.setContent(template1 );
                else
                if(graphic.attributes.OBJECTID == 2){
                   infoTemplate.setContent(template2 );
                else
                if(graphic.attributes.OBJECTID == 3){
                   infoTemplate.setContent(template3  );
   featureLayer.on("mouse-out", function ()
    map.infoWindow.hide();
   dojo.connect(featureLayer, "onMouseOver", function (evt) {
            map.setMapCursor("pointer");
         dojo.connect(featureLayer, "onMouseOut", function () {
            map.setMapCursor("default");
   map.addLayer(featureLayer);
         map.setExtent(extent );
   var resizeTimer;
   dojo.connect(map, 'onLoad', function(theMap) {
   dojo.connect(dijit.byId('map'), 'resize', function() {
   clearTimeout(resizeTimer);
   resizeTimer = setTimeout(function() {
   map.resize();
   map.reposition();
   }, 500);
  dojo.ready(init);
  dojo.addOnLoad(init);
</script>
</head>
<body>
   <!-- ******************************************************** Map ******************************************************* -->
     <div id="mapDiv">             </div>
</body>
</html>
I have this code and I'm trying to display the infoTemplate on hover. I tried the above but it's not working. However, it's working when I click on the feature points(it displays the right template depending on the OBJECTI). but I want it to work on hover too it won't even change the mouse to pointer
I'm new to arcgis and javascript please help.
RobertScheitlin__GISP
Isra,
  It is hard to test as there are so many js and css files that are local pathed. But Just by scanning the js code for syntax issues, I see that you are missing the }); from your
So it should look like:
         infoTemplate.setContent(template1);
      else
         infoTemplate.setContent(template2);
      else
         infoTemplate.setContent(template3);
