AnsweredAssumed Answered
Activate Editor and Deactivate Editor and Editor Info Window
Question asked by rhyck.m on Oct 28, 2014
Latest reply on Oct 28, 2014 by rhyck.m
I am using API 3.10 and I am trying to Activate Editor on Button Click and deactivate the Edit when the button is clicked again. on page Page Load I set the EditContent Pane css to display none and display it on button click.
Also calling InitEditor on button click does not seem to work, the editor is not loading neither the TemplatePicker not event the Editor InfoTemplate.
here is my code:
appEdit = {
        showEditPanel: function () {
            var node = registry.byId("btnEditLayer");
            var panel = dojo.byId("EditContent");
            var value = node.get("label");
            if (value == "Start Edit") {
                domStyle.set(registry.byId("EditContent").domNode, { 'display': 'block' });
                registry.byId("mainWindow").resize();
                node.set("label", "Stop Edit");
                initEditor();
            else if (value == "Stop Edit") {
                domStyle.set(registry.byId("EditContent").domNode, { 'display': 'none' });
                node.set("label", "Start Edit");
                destroyEditor();
here are the functions InitEditor and DestroyEditor
 function initEditor(evt) {
        var templatePicker = new TemplatePicker({
            featureLayers: [permit, sitePlan],
            grouping: true,
            rows: "auto",
            columns: 3
        }, "templateDiv");
        templatePicker.startup();
        var layers = arrayUtils.map(evt.layers, function (result) {
            return { featureLayer: result.layer };
        var settings = {
            map: map,
            templatePicker: templatePicker,
            layerInfos: layers,
            toolbarVisible: true,
            createOptions: {
                polylineDrawTools: [esri.dijit.editing.Editor.CREATE_TOOL_FREEHAND_POLYLINE],
                polygonDrawTools: [esri.dijit.editing.Editor.CREATE_TOOL_FREEHAND_POLYGON]
            toolbarOptions: {
                reshapeVisible: true
        var params = { settings: settings };
        var myEditor = new Editor(params, 'editorDiv');
        //define snapping options
        var symbol = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_CROSS,
          15,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_SOLID,
            new Color([255, 0, 0, 0.5]),
            5
          null
        map.enableSnapping({
            snapPointSymbol: symbol,
            tolerance: 20,
            snapKey: keys.ALT
        myEditor.startup();
    function destroyEditor() {
        if (editorWidget) {
            editorWidget.destroy();
            editorWidget = null;
Outcomes
