AnsweredAssumed Answered
Tutorial: Advanced web map printing/exporting using arcpy.mapping
Question asked by Geohab on Oct 24, 2014
Latest reply on Feb 22, 2017 by shruthi13
Hi All,
I have followed the step-by-step instructions of the (
) tutorial in ArcGIS Resources and it all works well. I have tested the geoprocessing service in ArcMap using a GIS server connection to my ArcGIS for Server and it works well. I copied and pasted the ArcGIS API for JavaScript code to the sandbox and changed the URLs of the map service and geoprocessing service to my server and run it. The results show that everything displayed well, however when I clicked on the print button it doesn't print anything. I know the HTML version used in this example is HTML 4.01 and JavaScript API version is 3.0. Can anyone please help me fix the print problem and change the code to the current version of JavaScript API 11 (or 10) and HTML 5?
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.0/js/dojo/dijit/themes/claro/claro.css">
    <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.0/"></script>
    <script type="text/javascript" language="Javascript">
      dojo.require("esri.map");
      dojo.require("esri.tasks.PrintTask");
      dojo.require("dijit.form.Button");
      dojo.require("dijit.form.CheckBox");
      dojo.require("dijit.form.ComboBox");
      var layer, map, visible = [];
      var printTask, params;
      function init() {
        var startExtent = new esri.geometry.Extent({"xmin":-2260000,"ymin":-1500000,"xmax":2250000,"ymax":1220000,"spatialReference":{"wkid":102008}});
        map = new esri.Map("map", {extent:startExtent});
        var dynUrl = "http://myserver:6080/arcgis/rest/services/USA/ConterminousUSA/MapServer";
        layer = new esri.layers.ArcGISDynamicMapServiceLayer(dynUrl, { "id": "ConterminousUSA" });
        if (layer.loaded) {
          buildLayerList(layer);
        else {
          dojo.connect(layer, "onLoad", buildLayerList);
  var printUrl = "http://myserver:6080/arcgis/rest/services/USA/AdvancedHighQualityPrinting/GPServer/AdvancedHighQualityPrinting";
  printTask = new esri.tasks.PrintTask(printUrl, {async: true});
  params = new esri.tasks.PrintParameters();
        params.map = map;
      function buildLayerList(layer) {
        var items = dojo.map(layer.layerInfos,function(info,index){
          if (info.defaultVisibility) {
            visible.push(info.id);
          return "<input type='checkbox' class='list_item' checked='" + (info.defaultVisibility ? "checked" : "") + "' id='" + info.id + "' onclick='updateLayerVisibility();' /><label for='" + info.id + "'>" + info.name + "</label>";
        dojo.byId("layer_list").innerHTML = items.join();
        layer.setVisibleLayers(visible);
        map.addLayer(layer);
      function updateLayerVisibility() {
        var inputs = dojo.query(".list_item"), input;
        visible = [];
        dojo.forEach(inputs,function(input){
          if (input.checked) {
              visible.push(input.id);
        //if there aren't any layers visible set the array to be -1
        if(visible.length === 0){
          visible.push(-1);
      function print(){
        var layout = dojo.byId("layout");
        var index = layout.selectedIndex;
  var selectedValue_layout = layout.options[index].value;
  var format = dojo.byId("format");
        var index = format.selectedIndex;
  var selectedValue_format = format.options[index].value;
  var georef_info = dojo.byId("georef_info");
        var index = georef_info.selectedIndex;
  var selectedValue_georef_info = georef_info.options[index].value;
  var legendLayer = new esri.tasks.LegendLayer();
  legendLayer.layerId = "ConterminousUSA";
  legendLayer.subLayerIds = [];
  if (CapitalCities.checked == true)
      legendLayer.subLayerIds.push(0);
  if (InterstateHighways.checked == true)
      legendLayer.subLayerIds.push(1);
      if (Rivers.checked == true)
      legendLayer.subLayerIds.push(2);
      if (Lakes.checked == true)
      legendLayer.subLayerIds.push(3);
      if (StateBoundaries.checked == true)
      legendLayer.subLayerIds.push(4);
        params.template = {layout: selectedValue_layout, format: selectedValue_format, layoutOptions: {legendLayers:[legendLayer]}};
        params.extraParameters = {Georef_info: selectedValue_georef_info};
        printTask.execute(params, printComplete);
      function printComplete(result){
        window.open(result.url);
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    <div id="map" style="width:1000px; height:600px; border:1px solid #000;"></div>
    <br />
    Layout Template:
    <select id="layout" >
      <OPTION value="CentralUSA">CentralUSA</OPTION>
  <OPTION value="ConterminuousUSA">ConterminuousUSA</OPTION>
  <OPTION value="NortheasternUSA">NortheasternUSA</OPTION>
  <OPTION value="NorthwesternUSA">NorthwesternUSA</OPTION>
  <OPTION value="SouthernUSA">SouthernUSA</OPTION>
  <OPTION value="SouthwesternUSA">SouthwesternUSA</OPTION>
    </select>
      Format:
    <select id="format">
      <OPTION value="PDF">PDF</OPTION>
  <OPTION value="PNG">PNG</OPTION>
    </select>
      Include Georef info?
    <select id="georef_info">
      <OPTION value="True">True</OPTION>
  <OPTION value="False">False</OPTION>
    </select>
    <br /><br />
    Table of Contents: <br /><span id="layer_list"></span>
    <br /><br />
    Include in Legend: <br />
    <label><input type="checkbox" name="CapitalCities" checked="checked">Capital Cities</label>
  <label><input type="checkbox" name="InterstateHighways" checked="checked">Interstate Highways</label>
  <label><input type="checkbox" name="Rivers" checked="checked">Rivers</label>
  <label><input type="checkbox" name="Lakes" checked="checked">Lakes</label>
  <label><input type="checkbox" name="StateBoundaries" checked="checked">State Boundaries</label>
  <br /><br />
  <input type="button" id="print" value="Print" onclick="print();"/>
  </body>
</html>
Outcomes
