AnsweredAssumed Answered
the local server start but the window popped up shows nothing?
Question asked by nocefly on Oct 22, 2014
Latest reply on Nov 1, 2014 by nocefly
Hi, i installed ArcGIS Runtime Qt 10.2.3. Local server failed to start when i test the first sample. It seems the ArcGISRuntime::installDirectory() returns null because the path  returned is not right. When i set the install path by using setInstallDirectory function, the local server works. However, the window popped up shows nothing.
Code:
    QString mypath="/home/wu/arcgis/runtime_sdk/qt10.2.3";
    EsriRuntimeQt::ArcGISRuntime::setInstallDirectory(mypath);
    EsriRuntimeQt::ArcGISRuntime::setRenderEngine(EsriRuntimeQt::RenderEngine::OpenGL);
    m_mapGraphicsView = EsriRuntimeQt::MapGraphicsView::create(m_map, this);
    setCentralWidget(m_mapGraphicsView);
    m_map.setWrapAroundEnabled(false);
    // show Esri logo by default
    m_map.setEsriLogoVisible(true);
    QString path = EsriRuntimeQt::ArcGISRuntime::installDirectory();
    path.append("/sdk/samples/data");
    QDir dataDir(path); // using QDir to convert to correct file separator
    QString pathSampleData = dataDir.path() + QDir::separator();
    QString dataPath = pathSampleData + "mpks" + QDir::separator() + "USCitiesStates.mpk";
    m_localMapService = EsriRuntimeQt::LocalMapService(dataPath);
  // connect to signal that is emitted when the service is created successfully
     connect(&m_localMapService, SIGNAL(serviceCreationSuccess(const QString&, const QString&)), this, SLOT(onLocalServiceCreationSuccess(const      QString&, const QString&)));
  // connect to signal that is emitted when the service failed
     connect(&m_localMapService, SIGNAL(serviceCreationFailure(const QString&)), this, SLOT(onLocalServiceCreationFailure(const QString&)));
  // start the service and the Local Server
     m_localMapService.start();
Outcomes
