How would I configure the Beta AGOL Web Appbuilder geocode widget for a "place name" or "point of interest"? When I put in a map service that has a field called PLACE_NAME, it never validates?
Map service: http://mapservices.phoenix.gov/arcgis/rest/services/POP/PointsofPride/MapServer/0
Solved! Go to Solution.
The Geocoder URL here needs a Geocoding service not a map service. You need to create a locator based on the POI with the single line style and then share that as a service. Then you can take that URL and add it to the Geocoder widget in WAB.
Thank you Stan!
