After insert lower() there's nothing written in the field? What's wrong?
# Process: Feld berechnen
arcpy.CalculateField_management(FeldHinzugefuegt, "Pfad", "\"U:\\rips\\images\\tk50\\tk\" & ([BLATT_NR].lower()) & \"co\" & \"*.*\"", "VB", "")
Solved! Go to Solution.
The VBScript function is LCase, as in
LCase("STRING")
I really like splitting long Python statements on multiple lines; the interpreter ignores the newline if you are inside ( 😞
# VB Parser
("\"U:\\rips\\images\\tk50\\tk\" & LCASE([BLATT_NR])"
"& \"co\" & \"*.*\"",
"VB")'
# Python Parser (better, and will run in arcpy 64)!
("\"U:\\rips\\images\\tk50\\tk"
"{}\\co\\*.*\".format(!BLATT_NR!).lower()"),
"PYTHON")
I'd put the calculation expression in a variable and check that. It kind of looks like your quotation marks are off, but honestly it's a bit hard to follow all that.
Thanks for the answer. The field calculation work without lower() function, so don't care about all the funny text around.
This must be the problem. Or can`t you lower the expression of a field string in this manner?
I don't believe ".lower()" can be used with the VB parser. That is Python.
LCase("STRING")
# VB Parser
"VB")'
"PYTHON")
Untested:
Likely what will work:
arcpy.CalculateField_management(FeldHinzugefuegt, "Pfad", r"U:\rips\images\tk50\tk\\" + ([BLATT_NR].lower()) + "co\\" + "*.*", "PYTHON_9.3", "")
Or from your original code:
arcpy.CalculateField_management(FeldHinzugefuegt, "Pfad", "\"U:\\rips\\images\\tk50\\tk\" + ([BLATT_NR].lower()) + \"co\" + \"*.*\"", "PYTHON_9.3", "")
do it manually first then copy the syntax from the field calculator expression, fields in python are enclosed in ! ! marks, if that makes a difference
Thanks for your answers, but I can't follow them or they don't work.
I try now to get a model to work and then export to python.
!BLATT_NR!.lower()
This works in the model
"U:\\rips\\images\\tk50\\" & !BLATT_NR!.lower() & "co.*"
For this I get a error message?
ERROR 000539: Error running expression: "U:\\rips\\images\\tk50\\" & "L6518".lower() & "co.*"
File "<expression>", line 1, in <module>
TypeError: unsupported operand type(s) for &: 'str' and 'str'
What's the problem?
What I need:
"U:\\rips\\images\\tk50\\l6518co.*"
This is for the model ok:
"U:\\rips\\images\\tk50\\" + !BLATT_NR!.lower() + "co*.*"
Result export to python:
arcpy.CalculateField_management(Orthos_Nummern_Layer, "Pfad", "\"U:\\\\rips\\\\images\\\\tk50\\\\\"
+ !BLATT_NR!.lower() + \"co*.* \"", "PYTHON", "")
No field calculate?
Tried this:
arcpy.CalculateField_management(Orthos_Nummern_Layer, "Pfad", "\"U:\\rips\\images\\tk50\\\"
No field calculate?
