Rename layer with unsupported signs in a mxd via python?
1412
10-16-2014 12:43 AM
JohannesBierer
Occasional Contributor III
Does someone have a code example?
JohannesBierer
Right solution is:
lyrname.decode('utf-8')
JohannesBierer
This:
import arcpy
import os
mxd = arcpy.mapping.MapDocument("CURRENT")
for lyr in arcpy.mapping.ListLayers(mxd):
    if lyr.supports("DATASOURCE"):
        arcpy.AddMessage("Layer: " + lyr.name + "  Source: " + lyr.dataSource)
    lyrname = str(lyr.name)
    print lyrname
    lyrname_replaced = lyrname.replace(" ","_")
    lyr.name = lyrname_replaced
    arcpy.AddMessage(lyrname_replaced)
arcpy.RefreshTOC()
leads to this error:
File "R:\Karto\zGIS\Python\RenameLayerinMxd.py", line 16, in <module>
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe4' in position 3: ordinal not in range(128)
Any ideas?
JohannesBierer
If I use
lyrname.encode('utf-8')
This leads to:
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 3: ordinal not in range(128)
JohannesBierer
Right solution is:
