utcOffset in Popup Template
1435
10-16-2014 10:13 AM
IsaiahAguilera
Occasional Contributor II
So I have a popup template that is referencing a date field that is not stored in UTC so by default the popup converts what it thinks is UTC to our time zone. However the date field is already stored in our local time so I need to specify the UTC offset manually. I see there is a way to do this in the API docs for popuptemplate and it is called utcOffset however it is not clear on where exactly to put it.  I have tried various places but have not been successful. Any help would be greatly appreciated.
var template = new PopupTemplate({
            title: "Incident",
            fieldInfos: [{
                fieldName: "alarmdate",
                label: "Alarm Date:",
                visible: true
                fieldName: "incidentnumber",
                label: "Inc. #:",
                visible: true
                fieldName: "CallCode",
                label: "Call Code:",
                visible: true
                fieldName: "compositeaddress",
                label: "Address:",
                visible: true
                fieldName: "Units",
                label: "Unit(s):",
                visible: true
            showAttachments: true
The alarmdate field is the one I am trying to add the utcOffset to I would need it to be something like +7.
DallasShearer
have you tried this?
title: "Incident",
fieldInfos: [{
  },{utcOffset: 300});
DallasShearer
title: "Incident",
fieldInfos: [{
IsaiahAguilera
This worked thank you for your help!
