e-search widget
5336
21
10-15-2014 10:59 AM
glennhazelton
Occasional Contributor III
I have a problem with Robert Scheitlin's enhanced search widget.
I have it working in the web app builder configuration and I can modify the query and fields to be displayed etc. but when I click on the icon a white box appears with the 'loading' wheel spinning but nothing happens after that. what is the easiest way to debug what is going on. I figure I am missing something basic. likely a path in a config file somewhere but I am new to working with this code. any help appreciated.
Tags (1)
RobertScheitlin__GISP
Glenn,
  That's why it is called Beta. Esri changed an event name on me again in the symbolChooser.js. If you go in the DefaultSearchSym.js file and find the postCreate function and change these lines:
Old:
      this.own(on(this.defaultPointSymbolChooser,'Change',lang.hitch(this,this._onPointSymbolChange)));
      this.own(on(this.defaultLineSymbolChooser,'Change',lang.hitch(this,this._onLineSymbolChange)));
      this.own(on(this.defaultPolySymbolChooser,'Change',lang.hitch(this,this._onPolySymbolChange)));
New
      this.own(on(this.defaultPointSymbolChooser,'change',lang.hitch(this,this._onPointSymbolChange)));
      this.own(on(this.defaultLineSymbolChooser,'change',lang.hitch(this,this._onLineSymbolChange)));
      this.own(on(this.defaultPolySymbolChooser,'change',lang.hitch(this,this._onPolySymbolChange)));
The difference is the case of the event change.
Glenn,
   The version I have available for download is for Beta1 and I was going to release a Beta2 but I got so involved in adding all the Flex versions features that I never got around to finishing up the UI part and now I have a version that works in Beta 2 and 3 but the UI is out of sync with the widget core. I will try and find some time to get the Beta 1 version working in Beta 3 and update the download.
glennhazelton
ok thanks Robert
let me know when I can grab a version that will work with Beta 3.
I appreciate all your effort. this is a wonder search tool. I use it exclusively in my flexviewer.
Glenn,
   A version that works with Beta 3 is now uploaded. Keep in mind this is a far cry from where the Flex version of the eSearch is, as far as functionality.
Enhanced Search Widget Beta 3
glennhazelton
Thank You!!
I have it working.
As far as functionality I think it works well.
the ability to select graphically is a great plus.
it would be nice to be able to add-to or remove features with additional queries.
I have some users who want to be able filter features based on a value and then further refine it based on a date.
and of course exporting to a .csv file would be wonderful.
glennhazelton
Robert,
do you have the functionality to hyperlink to other documents in this version?
I see the 'linkfield' item in the config but I am not sure how to use it.
I am also wondering about 'attachments'
Glenn,
   Nope, the link nor the attachments is working yet in that version (I still have a lot of work to do).
glennhazelton
hi Robert,
I have just discovered the check box in the eSearch labeled "add results as operational layer"
can you explain how this works and how to set the default symbol for a point query.
I see that it does work and I can display the attributes for the results.
but
the symbology doesn't seem to be working  as there is nothing showing on the map.
the symbol I see in the layer list is a circle with a "x" inside it.
this tool will solve my 'filtering' issue, as if it works I can turn off the full dataset and just display the results of the query.
and one more question....
the symbol for the results is the binoculars from the flex viewer.
there is a gui in the webappbuilder to change the default symbol. but it doesn't work with the esearch.
I can set it to something else and save but when I run the querytool it reverts to the binoculars.
if I wanted to use the big blue circle that is the default in the esri query tool how would I alter your config?
Glenn,
Old:
New
glennhazelton
great, thanks
it works.
I assume you are working on adding the multiple query options like you have in the flex version so queries can be used to add to or remove from a selected set as well.
