Feature Layer Query Error
4083
10-13-2014 05:06 PM
joepublic
New Contributor III
I'm trying to understand how to query a feature layer and getting the following error:
ReferenceError {stack: "ReferenceError: Query is not defined↵    at http:/…  at d (http://js.arcgis.com/3.10/init.js:74:10)",
message: "Unable to draw graphic (geometry:null, symbol:null): Query is not defined"}
Query is not defined" stack: "ReferenceError: Query is not defined↵    at http://tobagoborn.com/esri/examples/exam1.html:40:24↵    at null. (http://js.arcgis.com/3.10/init.js:777:175)↵    at h.(anonymous function).g
[as onLoad] (http://js.arcgis.com/3.10/init.js:239:390)↵    at v (http://js.arcgis.com/3.10/js/esri/layers/FeatureLayer.js:24:225)↵
at S._forceIdentity (http://js.arcgis.com/3.10/js/esri/layers/FeatureLayer.js:50:338)↵    at S._initLayer (http://js.arcgis.com/3.10/js/esri/layers/FeatureLayer.js:25:72)↵
at Object. (http://js.arcgis.com/3.10/init.js:174:23)↵    at http://js.arcgis.com/3.10/init.js:630:478↵
at c (http://js.arcgis.com/3.10/init.js:74:221)↵    at d (http://js.arcgis.com/3.10/init.js:74:10)"
Script below:......
<html>
  <head>
  <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
  <title>Basic Example 1</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
  <script src="http://js.arcgis.com/3.10/"></script>
  <script src="//ajax.googleapis.com/ajax/libs/jquery/1.8.0/jquery.min.js"></script>
  <script type="text/javascript">
  var countries;
  var buttonPicked;
  var buttonType;
  var countryCode = [];
  var map, featureLayer, relatedTable;
  var featureURL = "http://dev.consciousglobalchange.org/arcgis/rest/services/MEP/webmap_catalog/FeatureServer/0";
  var relatedURL = "http://dev.consciousglobalchange.org/arcgis/rest/services/MEP/webmap_catalog/FeatureServer/1";
  function countries()
  require(["esri/map",
  "esri/layers/FeatureLayer",
  "esri/tasks/query",
  "dojo/domReady!"
  ], function(Map,FeatureLayer)
  map = new Map("mapDiv",
  center: [-56.049, 38.485],
  zoom: 3,
  basemap: "streets"
  var featureLayer = new FeatureLayer(featureURL,
  outFields: ["*"]
  featureLayer.on("load", function ()
  var cntryq = new Query();
  cntryq.outFields = ["*"];
  cntryq.where = "UN = " + 840; //332
  countries.queryFeatures(cntryq, function(featureSet)
  var data = featureSet.features;
  console.log(data);
  }); //end of on
  //map.addLayer(featureLayer);
  }); //end require
  countries();
  </script>
  </head>
  <body>
  <div id="mapDiv"></div>
</body>
</html>
Tags (1)
joepublic
New Contributor III
Figured it out!!
Needed to include the Query keyword in the function after the require array
joepublic
New Contributor III
Figured it out!!
