Change graphic selection template
3641
5
10-13-2014 03:34 AM
NicolasVIOT
Hi everyone,
I'm trying to change the selection template of a layer without success...
What I've donne :
  • In view :
<esri:GraphicsLayer ID="LinesLayer" MouseLeftButtonDown="LinesLayer_MouseLeftButtonDown" x:Name="_grl_line" SelectionColor="Transparent">
  • In graphic creation code  :
graphicLine.PropertyChanged += new PropertyChangedEventHandler((o, p) =>
    if (p.PropertyName != "Selected") return;
    var selectedLine = (Graphic)o;
    selectedLine.Symbol = selectedLine.Selected ? SelectedLineSymbol : DefaultLineSymbol;
And this is the result :
There still is a border on my lines objects and I want to hide it...
Thanks in advance.
JenniferNery
If you left UseAcceleratedLayers=False (default), you can refer to the following SDK sample to see how you can update symbol template and update selection state via VisualStateManager. ArcGIS API for Silverlight - Interactive Samples | ArcGIS for Developers.
JenniferNery
NicolasVIOT
Thanks for your help Jennifer !
What I've done :
  • In Application.xaml :
            <esri:LineSymbol x:Key="LineSymbol">
                <esri:LineSymbol.ControlTemplate>
                    <ControlTemplate>
                        <Path x:Name="Element"
  Stroke="Yellow"
  StrokeStartLineCap="Round"
  StrokeThickness="2"
  StrokeLineJoin="Round"
  StrokeEndLineCap="Round">
                            <VisualStateManager.VisualStateGroups>
                                <!--<VisualStateGroup x:Name="CommonStates">
                                        <VisualState x:Name="MouseOver">
                                            <Storyboard>
                                                <ColorAnimation Storyboard.TargetName="Element"
                                                Storyboard.TargetProperty="(Path.Stroke).(SolidColorBrush.Color)"
                                                To="Orange" />
                                            </Storyboard>
                                        </VisualState>
                                    </VisualStateGroup>-->
                                <VisualStateGroup x:Name="SelectionStates">
                                    <VisualState x:Name="Unselected" />
                                    <VisualState x:Name="Selected">
                                        <Storyboard>
  To="Orange" Duration="00:00:00.25" />
                                            <DoubleAnimation Storyboard.TargetName="Element"
  Storyboard.TargetProperty="StrokeThickness"
  To="3"  Duration="00:00:00.25" />
                                        </Storyboard>
                                    </VisualState>
                                </VisualStateGroup>
                            </VisualStateManager.VisualStateGroups>
                        </Path>
                    </ControlTemplate>
                </esri:LineSymbol.ControlTemplate>
            </esri:LineSymbol>
            <esri:LineSymbol x:Key="LineOverSymbol">
                    <ControlTemplate>
  Stroke="LimeGreen"
  StrokeThickness="2"
                                            <Storyboard>
                                                To="Orange" />
                                            </Storyboard>
                                        </VisualState>
                                        <Storyboard>
  To="Green" Duration="00:00:00.25" />
                                        </Storyboard>
                                    </VisualState>
                                </VisualStateGroup>
                        </Path>
                    </ControlTemplate>
            </esri:LineSymbol>
  • In my Graphics factory :
        public static LineSymbol LineSymbol = App.Current.Resources["LineSymbol"] as LineSymbol;
        public static LineSymbol LineOverSymbol = App.Current.Resources["LineOverSymbol"] as LineSymbol;
            graphicLine.MouseEnter += new MouseEventHandler((o, m) =>
                var lineGraphic = (Graphic)o;
                lineGraphic.Symbol = LineOverSymbol;
            graphicLine.MouseLeave += new MouseEventHandler((o, m) =>
                lineGraphic.Symbol = LineSymbol;
And I get this error when I try to add graphics to my layer :
linesLayer.Graphics.Add(graphicLine);
Error : Graphic Symbol n’est pas sérialisable sur JSON
Have you an idea on what is the problem ?
MichaelBranscomb
Esri Frequent Contributor
The error "Graphic Symbol is not serializable to JSON" is caused by using custom symbols (i.e. ControlTemplates) with the accelerated display mode. As Jennifer noted, in order to use such custom symbols you will need to set Map.UseAcceleratedDisplay to False.
Ideally we recommend you should use the accelerated display mode which is particularly beneficial for GraphicsLayers and FeatureLayers in WPF. Additionally, this will help your migration to the new .NET SDK in which the accelerated display mode is the only map rendering mode.
One way around this is to consider using a UniqueValueRenderer with two classes/values and two different symbols instead of selections and use an attribute change to indicate selected state of your graphics.
Cheers
Mike
NicolasVIOT
Oh sorry.. my fault I didn't saw I had set UseAcceleratedDisplay to True...
Thanks you two very much.
Is the accelerated display mode optimized the display of my objects on map and by the way upgrade the fluidity of my application?
MichaelBranscomb
Correct, the accelerated display is an optimized map rendering engine. You may not notice any significant difference for tiled and dynamic map service layers but you should notice a substantial difference when using GraphicsLayers and FeatureLayers. But there are some drawbacks - custom symbols and KML layers are not supported in this mode.
There are some additional guidelines to using the accelerated display mode in the .NET Guide documentation: Performance considerations—ArcGIS Runtime SDK for .NET | ArcGIS for Developers (it will not mention the "accelerated display" because it only uses that display pipeline).
Of particular note is the advice on Dynamic and Static rendering modes, which are supported in the WPF API on GraphicsLayers and FeatureLayers (ArcGIS Runtime SDK for Microsoft WPF - Library Reference ).
Cheers
Mike
