I'm trying to create a composite locator in ArcCatalog 10.2.2. It has 8 individual locators, 4 with an alternate name table, 4 without. We already have a working 10.1 version, but 10.2 is presumably faster and has a couple improvements we want to use, such as not confusing streets with states as their name as actual state namess (e.g., 'Montana' is the name of a street). We also have updated data to use.
I built it fine, all properties set the same as the 10.1 version. But it won't run the 4 locators with the alternate name table. When I look at the properties of those individual locators, everything looks good. Then I try a rebuild on them, and it says they need to be repaired. Okay, go to repair...
There I look at the Reference data tables section. In the field map (see attached):
If I set any of the missing values and click Ok, ArcCatalog shuts down immediately with no messages. On re-opening it, no repairs have been made.
Other info:
And now, to top it off, ArcCatalog shuts down with a '...has stopped working' error message whenever I try to create a new locator. This happened after a co-worker and I made some new locators, trying to change some things such as indexing AltID in the primary table. Can still create other new things, such as tables, fgdbs, etc.
Any help is much appreciated. Thanks.
Update - I can create locators in ArcCatalog in ArcMap, but not in ArcCatalog alone.
