Making dijit combo boxes required field
433
10-08-2014 11:17 AM
GeoffreyWest
Occasional Contributor III
I would like two combo boxes to be required before submitting a request, so if one value is chosen in the origin box, two other combo boxes are required to submit the request.
This allows for the type of request; if a certain request is chosen, say E-WASTE from this box, then before the user submits the request, the TYPE of e-waste must be required, in addition to the quantity.
All combo boxes reference the same layer.
First block of code (taken from a related question) is somewhat of a start, where should the layer be reference to loop through and set the value of my E-Waste request type field?
Second block shows the function for populating the request type combo box, in this case E-WASTE is chosen from the second block of code and passed to the first.
dijit.byId("cbRequestType").on('change', function (EWASTEVALUE) {
    if (EWASTEVALUE== 'E-WASTE') {
    dijit.byID("cbEWASTE").set('value', '');
    else if (MFValue == '...') {
      dijit.by.ID('cbEWASTE').set('value', '');
function PopulateRequestTypesPriority(serviceRequestLayerFieldsPriority) {
   var serviceRequestFieldsPriority
   for (var i = 0; i < serviceRequestLayerFieldsPriority.length; i++) {
   if (serviceRequestLayerFieldsPriority.name == serviceRequestLayerInfo.RequestPriorityFieldName) {
       serviceRequestFieldsPriority = serviceRequestLayerFieldsPriority.domain.codedValues;
            break;
    var serviceRequestPriority = { identifier: "id", items: [] };
    for (var i = 0; i < serviceRequestFieldsPriority.length; i++) {
        serviceRequestFieldsPriority.items = { id: serviceRequestFieldsPriority.name, name: serviceRequestFieldsPriority.name };
    var serviceRequestStorePriority = new dojo.data.ItemFileReadStore({ data: serviceRequestTypesPriority });
    dijit.byId('cbRequestPriority').attr('store', serviceRequestStorePriority);
function PopulateRequestTypesPriority(serviceRequestLayerFields) {
    for (var i = 0; i < serviceRequestLayerFields.length; i++) {
        if (serviceRequestLayerFields.name == serviceRequestLayerInfo.RequestPriorityFieldName) {
            serviceRequestFields = serviceRequestLayerFields.domain.codedValues;
            break;
    var serviceRequestTypes = { identifier: "id", items: [] };
    for (var i = 0; i < serviceRequestFields.length; i++) {
        serviceRequestTypes.items = { id: serviceRequestFields.name, name: serviceRequestFields.name };
    var serviceRequestStore = new dojo.data.ItemFileReadStore({ data: serviceRequestTypes });
    dijit.byId('cbRequestPriority').attr('store', serviceRequestStore);
