I can't get my map onClick events to fire on an iPhone
2678
10-08-2014 06:15 PM
TrevorScott1
Using iOS 8, and it works in the browser. This is an extremely urgent and important problem - any guidance or input would be greatly appreciated. Thank you in advance!
Here is my code if you are curious:
<script>
      var map;
      var graphic;
      var currLocation;
      var watchId;
      var caseArray = [
        <apex:repeat value="{!cwlist}" var="cw">
            {id:"{!cw.c.id}",lat:"{!cw.Latitude}",long:"{!cw.longitude}",description:"{!cw.description}",subject:"{!cw.subject}",img:"{!cw.img}",requestDate:"{!cw.infoDate}",address:"{!cw.c.Address__c}",icon:"{!cw.c.Icon_String__c}"},
        </apex:repeat>
        require([
        "esri/map",
        "esri/geometry/Point",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/graphic",
        "esri/Color",
        "esri/layers/GraphicsLayer",
        "dojo/domReady!"
      ], function(
        Map, Point, SimpleMarkerSymbol, SimpleLineSymbol, Graphic, GraphicsLayer,Color
        var lastItemIndex = caseArray.length-1;
        map = new Map("map", {
          basemap: "streets",
          autoResize:false,
          center: [caseArray[lastItemIndex].long,caseArray[lastItemIndex].lat],
          zoom: 14
        //MAP ON LOAD CODE
        map.on("load", function() {
          //default icon
          var s = new esri.symbol.PictureMarkerSymbol("https://cdn1.iconfinder.com/data/icons/Map-Markers-Icons-Demo-PNG/256/Map-Marker-Marker-Outside-Azur...",30,30);
          var p;
          var g;
          for(var i = 0; i < caseArray.length; i++) {
              console.log('adding graphic...');
              p = new Point(caseArray.long,caseArray.lat);
              s = new esri.symbol.PictureMarkerSymbol('https://na10.salesforce.com' + caseArray.icon,30,30);
              g = new Graphic(p, s).setAttributes({'id':caseArray.id,'subject':caseArray.subject,'description':caseArray.description,'img':caseArray.img,'requestDate':caseArray.requestDate,'longitude':caseArray.long,'latitude':caseArray.lat,'address':caseArray.address,'icon':caseArray.icon});
              map.graphics.add(g);
              //console.log(caseArray.lat+' ARG '+caseArray.long);
          //map.addLayer(gl);
          map.graphics.enableMouseEvents();
          dojo.connect(map.graphics, "onClick", function(e) {
            showRecord(e.graphic.attributes);
          if(navigator.geolocation ) {
            navigator.geolocation.getCurrentPosition(zoomToLocation, locationError);
            watchId = navigator.geolocation.watchPosition(showLocation, locationError);
          } else {
            alert("Browser doesn't support Geolocation. Visit http://caniuse.com to see browser support for the Geolocation API.");
        }); //End map on load
        map.on('reposition', function(evt) {
          console.log(evt.x+','+evt.y);
        function locationError(error) {
          //error occurred so stop watchPosition
          if( navigator.geolocation ) {
            navigator.geolocation.clearWatch(watchId);
          switch (error.code) {
            case error.PERMISSION_DENIED:
              alert("Location not provided");
              break;
            case error.POSITION_UNAVAILABLE:
              alert("Current location not available");
              break;
            case error.TIMEOUT:
              alert("Timeout");
              break;
            default:
              alert("unknown error");
              break;
        function zoomToLocation(location) {
          currentLongitude = location.coords.longitude;
          currentLatitude = location.coords.latitude;
          var pt = new Point(location.coords.longitude, location.coords.latitude);
          addGraphic(pt);
          map.centerAndZoom(pt, 15);
        function showLocation(location) {
          //zoom to the users location and add a graphic
          if ( !graphic ) {
            addGraphic(pt);
          } else { // move the graphic if it already exists
            graphic.setGeometry(pt);
          map.centerAt(pt);
        function addGraphic(pt){
          var symbol = new SimpleMarkerSymbol(
            SimpleMarkerSymbol.STYLE_CIRCLE,
            12,
            new SimpleLineSymbol(
              SimpleLineSymbol.STYLE_SOLID,
              new Color([210, 105, 30, 0.5]),
              8
            new Color([210, 105, 30, 0.9])
          graphic = new Graphic(pt, symbol);
          map.graphics.add(graphic);
        var is1 = true;
        function showInfoPanel(name, hideName, attributes) {
            //if (attributes.img != '') $('.'+name).find('.media-object').attr('src','/resource/'+attributes.img);
            $('.'+name).find('.media-object').attr('src',attributes.icon);
            $('.'+name).find('.media-heading').html(attributes.subject);
            $('.'+name).find('.media-date').html(attributes.requestDate);
            //$('.'+name).find('.media-text').html(attributes.description);
            console.log('Address:'+attributes.address);
            $('.'+name).find('.media-address').html(attributes.address);
            $('.'+name).attr('onclick','setCaseViewContent(\''+attributes.id+'\',\''+attributes.subject+'\',\''+attributes.description+'\',\''+attributes.latitude+'\',\''+attributes.longitude+'\',\''+attributes.img+'\',\''+attributes.requestDate+'\',\''+attributes.address+'\',\''+attributes.icon+'\');navigateTo(\'CaseView\');');
            $('.'+name).removeClass('fadeOutDown');
            $('.'+name).addClass('animated fadeInUp');
            $('.'+name).show();
            $('.'+hideName).removeClass('fadeInUp');
            $('.'+hideName).addClass('fadeOutDown');
        function showRecord(attributes) {
            console.log(attributes);
            console.log(attributes.id);
            if(is1) {
                console.log('is1 is true');
                showInfoPanel('caseInfoPanel','caseInfoPanel2',attributes);
                is1 = false;
            }else {
                console.log('is1 is false');
                showInfoPanel('caseInfoPanel2','caseInfoPanel',attributes);
                is1 = true;
            if($('.caseInfoPanel').is(":visible")) {
                console.log('info is showing');
                $('.caseInfoPanel').removeClass('animated fadeInUp');
                $(".caseInfoPanel" ).fadeOut( "50", function() {
                    $('.caseInfoPanel').addClass('animated fadeInUp');
                    $('.caseInfoPanel').show();
            }else{
    </script>
RachelAlbritton
Occasional Contributor III
I know this is pretty old but did you ever figure this out? I'm having the same issue.
