AnsweredAssumed Answered
trouble with export webmap to pdf
Question asked by troger80 on Oct 7, 2014
Hey having trouble getting a geoprocessing tool to export to pdf from a webmap correctly. I followed the tutorial ArcGIS Help 10.1 to create the geoprocessing tool and publish it. I access the tool using the geoprocessing widget in the flex viewer. The tool allows me to select a location to save the pdf and creates the pdf file but it does not create a pdf of the webmap.  Instead it creates a pdf of the template mxd file I used. Not
sure why it isn't reading any of the information from the webmap? Any help would be awesome Thanks.
import arcpy
import os
import uuid
# Input WebMap json
Web_Map_as_JSON = arcpy.GetParameterAsText(0)
# The template location in the server data store
templateMxd = '//CML/Facilities Management Application/map_temp/Landscape2.mxd'
# Convert the WebMap to a map document
result = arcpy.mapping.ConvertWebMapToMapDocument(Web_Map_as_JSON, templateMxd)
mxd = result.mapDocument
# Reference the data frame that contains the webmap
# Note: ConvertWebMapToMapDocument renames the active dataframe in the template_mxd to "Webmap"
df = arcpy.mapping.ListDataFrames(mxd, 'Webmap')[0]
# Remove the service layer
# This will just leave the vector layers from the template
for lyr in arcpy.mapping.ListLayers(mxd, data_frame=df):
    if lyr.isServiceLayer:
        arcpy.mapping.RemoveLayer(df, lyr)
# Use the uuid module to generate a GUID as part of the output name
# This will ensure a unique output name
output = 'WebMap_{}.pdf'.format(str(uuid.uuid1()))
Output_File = os.path.join(arcpy.env.scratchFolder, output)
# Export the WebMap
arcpy.mapping.ExportToPDF(mxd, Output_File)
# Set the output parameter to be the output file of the server job
arcpy.SetParameterAsText(1, Output_File)
# Clean up - delete the map document reference
filePath = mxd.filePath
del mxd, result
os.remove(filePath)
Outcomes
