Spatial Referencing Problems
4737
10-04-2014 05:07 AM
ClaireHarnett
I have some aerial photography data sets as an .ecw file and I want to import them into ArcGIS and then spatially reference them so I can just display them with a coordinate grid. I've imported the data fine, however I can't seem to assign a coordinate system that is recognised for the data. Is there a way I can upload the coordinate system in an accompanying .shp file?
Any help would be greatly appreciated,
Cheers,
Claire
Mohamed_MagdyMohamed_Hussain
New Contributor III
That is ERDAS ECW Plug-in 2014 for ArcGIS Desktop try it using this link Download ERDAS ECW Plug-in 2014 for ArcGIS Desktop | Intergraph
ClaireHarnett
Thanks, I downloaded the Plug-in. Does it then automatically work in ArcGIS?
PROBERT68
It should be able to display them. If you want to mosaic several of them in ecw, it might take a long time..so I would suggest to use Mosaic Dataset rather than mosaic them .
CodyBenkelman
Claire
Sorry I did not see this before.  Do you still need assistance with this?  The ECW files should already be georeferenced - if you drag and drop one into ArcMap, does it not display in the proper location?
Am I correct that  the ECW files are large mosaics, not single images which have never been rectified?
What version of ArcGIS do you have?
If you still need help let us know -
Cody B
