AnsweredAssumed Answered
help with fishnet
Question asked by bcelik_83 on Oct 5, 2014
I am new on arcgis. Here is short description what i am doing. I am trying to get data from night lights that is taken from satellites.
I am trying to get city level data for turkey. I can get it by selecting each city by one by one.
Here is the steps i am doing. Select-clip-create fishnet-convert from raster to polygon-clip(again) and get zonal statistic as table. I can do these city by city.
However i want to do it by using python. I can do it by using model builder. I can export the python script.
But when i want to change the values for another city, this time create fish net step in python is not getting XY coordinate values automatically.
Because when i do it one by one, it gets values automatically.
here is the command that i created and run from model builder.
# deneme.py
# Created on: 2014-10-05 12:47:05.00000
#   (generated by ArcGIS/ModelBuilder)
# Description:
# Import arcpy module
import arcpy
# Check out any necessary licenses
arcpy.CheckOutExtension("spatial")
# Local variables:
Turkiye = "Turkiye\\Turkiye"
turkiye_lights2012 = "turkiye_lights2012"
turkiye_lights2012_Clip21__2_ = "turkiye_lights2012_Clip21"
turkiye_lights2012_Clip21 = "C:\\Users\\Bilalce\\Documents\\ArcGIS\\Default.gdb\\turkiye_lights2012_Clip21"
Turkiye__2_ = "Turkiye\\Turkiye"
Tur_81_2012 = "C:\\Users\\Bilalce\\Documents\\ArcGIS\\Default.gdb\\Tur_81_2012"
RasterT_turkiy19 = "C:\\Users\\Bilalce\\Documents\\ArcGIS\\Default.gdb\\RasterT_turkiy19"
Tur_81_2012_Clip = "C:\\Users\\Bilalce\\Documents\\ArcGIS\\Default.gdb\\Tur_81_2012_Clip"
ZonalSt_Tur_81_1 = "C:\\Users\\Bilalce\\Documents\\ArcGIS\\Default.gdb\\ZonalSt_Tur_81_1"
# Process: Create Fishnet
arcpy.CreateFishnet_management(Tur_81_2012, "30.82083249005 40.61250013755", "30.82083249005 50.61250013755", "0.1", "0.1", "0", "0", "31.77083248625 41.12083346885", "NO_LABELS", "turkiye_lights2012_Clip21", "POLYGON")
# Process: Raster to Polygon
arcpy.RasterToPolygon_conversion(turkiye_lights2012_Clip21__2_, RasterT_turkiy19, "NO_SIMPLIFY", "Value")
# Process: Clip (2)
arcpy.Clip_analysis(Tur_81_2012, RasterT_turkiy19, Tur_81_2012_Clip, "")
# Process: Select Layer By Attribute
arcpy.SelectLayerByAttribute_management(Turkiye, "NEW_SELECTION", "\"IL\" = '81'")
# Process: Clip
arcpy.Clip_management(turkiye_lights2012, "25.6673999987543 35.8112000003457 44.8215000005126 42.1055999984562", turkiye_lights2012_Clip21, Turkiye__2_, "255", "ClippingGeometry", "NO_MAINTAIN_EXTENT")
# Process: Zonal Statistics as Table
arcpy.gp.ZonalStatisticsAsTable_sa(Tur_81_2012, "OID", turkiye_lights2012_Clip21, ZonalSt_Tur_81_1, "DATA", "MEAN")
You can see what i mean on the left side. When i do one by one, in the create fish net step, it is getting coordinates automatically after i chose input layer. However when i try to do it, i dont know which values to put. And it is giving me an error.
Thank you so much
Outcomes
