Project 2: Batch reprojection tool for vector datasets Penn State
4196
10-02-2014 07:24 AM
JordanLumber
This is my first time posting to a discussion board. I am in the process of taking Penn State's Geog 485 course on Python and GIS and I am stuck on an exercise.
Here is the url of the exercise: https://community.esri.com/discussion/create.jspa?sr=cmenu&containerType=14&containerID=1&draftID=31...
If anyone has any suggestion on how to make this code work or what I am doing wrong, I would really appreciate it
import arcpy  #Set workspace environment arcpy.env.workspace = "C:\\Users\\jtodd\\Dropbox\\PennState_OnlineCourses\\WCGIS\\Geog485\\Lesson2\\Lesson2Data"   #Input feature classes input_features = arcpy.ListFeatureClasses()   #Output workspace output_workspace = "C:\\Users\\jtodd\\Dropbox\\PennState_OnlineCourses\\WCGIS\\Geog485\\Lesson2\\Lesson2Data\\results"   #template dataset template = "Ferries.shp"   try:          #Geographic transformation - Determines 'template' spatial reference     desc = arcpy.Describe(template)     templateSR = desc.spatialReference     #print templateSR.Name #Check to make sure code is working up to this point       for featureClass in input_features:         desc = arcpy.Describe(featureClass)         fcListSR = desc.SpatialReference         #print fcListSR.Name #Check to make sure code is working up to this point           if fcListSR.Name != templateSR.Name:             arcpy.DefineProjection_management(input_features, templateSR)             print(arcpy.GetMessages(0))   except arcpy.ExecuteError:     print(arcpy.GetMessages(2))   except Exception as ex:     print(ex.args[0])
DanPatterson_Retired
can you repost the code it is on one line
