version 10.2.2 is not saving options
3782
10-02-2014 08:07 AM
ClintonJenkins
New Contributor III
When I change the options under the Customize menu, in this case changing the default raster resampling to be nearest neighbor, the change is not saved. When I open ArcMap again, it has stayed with the same options as it originally had. This also happens if I change the default band combinations. When I tried changing the Data View options, those changes also are not saved.
Anyone else have this problem? Any potential solutions?
curtvprice
MVP Esteemed Contributor
There is a known bug (not fixed). One of our users noted it after the 10.2 update.
Unfortunately, no workaround has been provided. Hope they can fix this soon, what a pain.
Bug NIM100671 Not all ArcMap Option settings are preserved between ArcMap sessions in ArcGIS 10.2.1,...
RhettZufelt
MVP Frequent Contributor
I noticed my 10.3 box was saving the changes so I looked in regedit.
I added these to my 10.2.1 settings and they now "stick".
R_
