Stand License, Arcgis Online (free account), Arcgis 10.1
I have an .xml doc in arcmap with Businesses (pt ft class), 2 different buffers (polygon ft class). I wanted to upload them to AGOL . I made a map package and saved it as a file instead of uploading it to AGOL because it would always stop responding until it completely exitted out of ArcMap. I want to upload the 3 features ArcGis Online and overlay it onto a basemap. It would be great if I can keep the Symbology and Attributes of the pt. ft. class.
Also a note, the point feature class is 1,600 points so when I tried before, it said that I have a limit of 1,000.
I would like to somehow overlaying this onto a basemap and hopefully keeping the symbology in the pt feature classs and have the buffers attached in the same doc. the attributes on the buffer are not important.
Is there a way I can accomplish all/some of my goals?
Hi William,
If you do not need to edit the points, you can create a cache of the MXD using the Manage Tile Cache tool. After the cache is created, export this to a Tile Package using the Export Tile Cache tool. You can then upload this to ArcGIS Online and create a tiled service from it. After the tiled service is created, you can publish the same MXD as a hosted feature service. This will allow to enable pop-ups for the tiled service.
