Time Settings
4115
10-01-2014 12:27 AM
PeterSmith3
New Contributor III
I've added a feature layer into a Web Map which contains time enabled data (event dates). The time slider appears in the map and plays correctly. However, I want to configure the time settings so that I can alter the Time Display values. The problem is that, when I click on 'Show Advanced Options' in the Time Settings window, nothing happens except that the 'Show Advanced Options' text disappears. The only thing I can do is adjust the playback speed.
Have I missed something obvious?
PeterSmith3
New Contributor III
All sorted. I've just tried the same thing with Firefox and everything works as it should do. I was using IE11 previously which, for some reason, wasn't displaying the page correctly.
I can now see and adjust the time settings as required.
PeterSmith3
New Contributor III
