AGO related items limit?
2116
09-30-2014 09:07 AM
MaryElliott
New Contributor III
In previous maps with related table data posted to AGO, the related data displays properly in the pop-ups.  However, this newly updated relate table contains over a thousand records, whereas previous related tables contained less than 900 records.. For the fist time, the pop up does not list the proper records, altho, interestingly, it does give the correct record count.  And, it always lists the first records in the related table.
Yes, before sharing the service, I do check that the relates are valid and giving correct results.
Any thoughts on how I might fix this, or if, indeed, there is a limit to the number of related records AGO maps can handle.?  Thx.
