Exporting data in XML file format
4418
09-26-2014 04:24 AM
CharlyParra
Hi. Is it posible to export shapefiles or rasters in XML file format from ArcGIS?
Thanks.
Tags (1)
JakeSkinner
Esri Esteemed Contributor
You can easily import the data into a geodatabase.  Here are the steps:
1.  Right-click on a folder in the catalog window > New > File Geodatabase
2.  Right-click on the File Geodatabase > Import > Feature Class (single) or Raster Dataset
JakeSkinner
Hi Charly,
No, the data must reside in a geodatabase in order to export to an XML file.
CharlyParra
Jake, Thanks.
And is there any way of achieving the XML export as a way around? Perhaps putting the data in some way in a geodatabase, or similar (anyway, I don't know what a geodatabase is)?
JakeSkinner
CharlyParra
Thank you Jake
