AnsweredAssumed Answered
ArcMap how to edit/show only editable fields
Question asked by jsn on Sep 25, 2014
Latest reply on Sep 25, 2014 by jsn
Hello everyone,
This is a question for ArcMap 10.0
When editing a feature class in ArcMap I would like only to give access and show to the editor the fields that are editable.
Some fields in the feature:
  • could be calculated using for example the Esri Attribute Assitant  -http://www.arcgis.com/home/item.html?id=e35580f27bce4782b95ea8296ac60927 - where for example the Municipality code could be calculated,
  • have default values that do not change,
  • are calculated after other fields are populated , for example concatenating a Township Range Sextion number with a sequential number to build an ID
  • system fields such as created date, modified date, created by, modified by are populated by program.
Is there a way to hide the fields on a data entry form instead of the attributes editor?
Outcomes
