Feature pop-ups - date - does not show time
5184
09-23-2014 05:53 AM
KjetilNymoen
New Contributor III
Hi.
I have a webmap with configured popup on a date field:PopupConf.JPG
Here you see the popup in the webmap viewer:
Created an Operation View in Dashboard, and do use Feature Pop-Ups.
I do open the Operation View in a browser, and the popup gives me the time:
Open the operation view in Dashboard but it does not give me the time in the popup, just the date:
Is this a bug in the Dashboard desktop client?
AdamRepsher
Occasional Contributor III
At the time you posted this question, I do not believe it was fixed yet.  It was eventually fixed, but it is now broken again.
ArcGIS Online‌ changed the configuration of the date/time popup.  It is explained HERE.
It appears that Operations Dashboard for ArcGIS‌ has not picked up on this new configuration, as it does not work anymore.  I asked the question here if you would like to follow that discussion:Date/Time (with seconds) in OD?
--Adam
AdamRepsher
Download v10.3 as soon as you can.  It appears to be fixed.
--Adam
TifPun
Hi Kjetil,
As Adam pointed out, with 10.3 Operations Dashboard you should be able to see the time value in popups. Please give the latest version of the app a try (you can download from it here) and let me know you still run into the issue.
Tif
