You know, the script runs, check various inputs and so forth.
If a requirement is not met, eg the feature is not the correct type or something, then bail out and print a meaningful message.
Currently I use sys.exit(), but this is not ideal and throws an error in python.
So, how do the experts do it?
Thanks in advance,
Neil
The Understanding message types and severity section in the help has some good tips.
Depending on the severity of the issue you can use:
I always used sys.exit()
Read the the "Error Handling" page of the help docs.
If this is a python script tool, it's best to take advantage of parameter validation on the inputs -- to filter the input choices and check inputs before the tool is even run. This makes your tool far easier to use.
Help 10.2: Understanding Validation In Script Tools
If you want to drop out of your script for some other reason - without generating an error, you can create a custom exception and handle it (as suggested by others above):
class HappyError(Exception):
pass
try:
raise HappyError("message")
except HappyError as msg:
arcpy.AddMessage(msg)
Proper way to declare custom exceptions in modern Python? - Stack Overflow
