I try do a buffer around selected one polygon, but no buffer shows up. here is some code if anyone can find out why. this is a html page.
function doBuffer(evt) {
var geometry = evt[0].geometry;
map = theMap;
symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID,
new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25]));
var gsvc;
gsvc = new esri.tasks.GeometryService("https://xxx.com/arcgis/rest/services/Utilities/Geometry/GeometryServer");
switch (geometry.type) {
case "point":
//var symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 10, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 1), new Color([0, 255, 0, 0.25]));
break;
case "polyline":
var symbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASH, new Color([255, 0, 0]), 1);
break;
case "polygon":
//var symbol = new esri.symbols.SimpleFillSymbol(SimpleFillSymbol.STYLE_NONE, new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOT, new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]));
break;
//var graphic = new esri.Graphic(geometry, symbol);
//theMap.graphics.clear();
//setup the buffer parameters
var params = new esri.tasks.BufferParameters();
params.distances = 500;
params.bufferSpatialReference = new esri.SpatialReference({ wkid: 32612});
params.outSpatialReference = theMap.spatialReference;
params.unit =eval("esri.tasks.GeometryService.UNIT_FOOT");
//polygon = new esri.geometry.Polygon(theMap.spatialReference);
//polygon.addRing(theMap.graphics.graphics[0].geometry.rings);
// params.geometries = [evt[0].geometry];
// gsvc.buffer(params, showBuffer);
if (geometry.type === "polygon") {
//if geometry is a polygon then simplify polygon. This will make the user drawn polygon topologically correct.
gsvc.simplify([geometry], function (geometries) {
params.geometries = geometries;
} else {
params.geometries = [geometry];
function showBuffer(bufferedGeometries) {
dojo.forEach(bufferedGeometries, function(geometry) {
theMap.graphics.add(graphic);
//end for buffer.
