Joining Two shapefiles
3025
5
09-16-2014 04:31 AM
OmarTaha
Hi, I have arcmap 10.2, and I have to shapefiles, I want to shape file one to read data from shape file two based on a foreign key in shape file one, is it possible to do that?? And this to avoid repeating data in the attribute tables.
Tags (1)
RiyasDeen
Occasional Contributor III
Hi Omar,
Have a look at this link, ArcGIS Help 10.1
OmarTaha
Hi Riyas,
I have looked at what you mentioned, what I need exactly, is to know is it possible to join or relate tow attribute tables from two different shape files?
RiyasDeen
Hi Omar,
Confused a bit here, Have you got two shape files or two shape files and two tables? either way you can join or relate any number of shape files provided there is a common field across between the shape files.
OmarTaha
I meant to join two shape files, not two tables, and I did it, Thanks
DanPatterson_Retired
the term is merge if the geometry is the same
