Operations Dashboard Bug? - Labels in Map Prevents Dashboard Browser View from Loading
12769
23
09-12-2014 08:33 AM
DanAllen
Occasional Contributor III
  1. Create ArcGIS.com map with a feature service hosted in ArcGIS.com
  2. Create Operation Dashboard View (desktop windows)
  3. Log into ArcGIS.com, and Open web version of Dashboard in Browser - Everything works great.
  4. Turn on labels in ArcGIS.com map
  5. Open Web version of Dashboard in Browser - Map never loads
  6. Turn Labels off In ArcGIS.com Map
  7. Open Web version of Dashboard in Browser - Map Still does not load
Is anyone else able to reproduce this error?
Dan
Tags (1)
MarkBockenhauer
Dan,
Yes, I have been able to reproduce this.
Labeling enabled with the mapviewer is currenlty not supported in Dashboard.
Mark
MarkBockenhauer
An update
The September update to ArcGIS online should enable label support for Operations Views opened in the web browser.
At the time of this writing there is no definitive timeline for when map viewer map labeling will be supported in the Windows Dashboard Application.
Mark
DanAllen
Thanks Mark.  That is good to know.
Dan
DriesHerzeel
Hi Mark,
could you provide an update when labeling would be supported in the Windows Dashboard Application? We are 5 months later now, any news?
thx,
Dries
RonKnepper
Still seems to not be working? I know labels are not supported in collector but from this post I am confused if I should see them in dashboard?  I have a feature service setup in arcmap to display labels and published.  I then enabled them in AGOL and they show fine on my webmap but using that webmap does not show the labels in dashboard.
ChristopherOlsen
Hi Ron,
Labels are not supported in the Operations Dashboard "desktop" application.  If you create a view with a webmap that has labels, those labels will not show in desktop.  There is an ESRI Support bug for this- ENH-000084219.
However, if you then open the view in the web browser version of Ops Dashboard, the labels are visible.
RonKnepper
Thanks, that is useful to know.  Its not a big issue as ops dash is pretty fast but if we want to see them that is a good alt option
RaphaelSiebenmann
New Contributor III
Is there a timeline yet for feature service label support is the desktop version of the operations dashboard?
AhmedAbd_El_Aziz
as we are at March 2016. is label support in the desktop version of the operations dashboard yet ?
but as workaround
if you could enable <label features> from ArcMap before Publishing service, you'll get this view at Ops Dashboard Desktop edition
