AnsweredAssumed Answered
Drawing Line Measurement Not Matching Buffer Distance
Question asked by csergent08 Champion on Sep 11, 2014
Latest reply on Oct 8, 2014 by ddemone
I need a line measurement to match my buffer distance. The code modifications should related to this article: Measuring distances and areas when your map uses the Mercator projection | ArcGIS Blog
Currently I have a buffer that uses a WKID of 4326 which appears to draw correctly with a measured buffer of 500 feet. The rest of the application uses a WKID 102100 which allows the application to display correctly, but the line tool is coming up with a measurement of about 150 feet more than the buffer. I have changed each 102100 one at a time even ones I did not think I should as I need this app to work in testing. Any idea where I am going wrong with my code so that my measurements work?
Here is my code:
/// <reference path="scriptaculous.js" />
/// <reference path="dragdrop.js" />
/// <reference path="effects.js" />
/// <reference path="rico.js" />
/// <reference path="ricoStyles.js" />
/// <reference path="ricoCommon.js" />
/// <reference path="ricoEffects.js" />
// Using Intellisense For The Above
// http: //msdn.microsoft.com/en-us/library/bb385682.aspx
////////// AUTHOR & APPLICATION INFORMATION ////////////////////////////////////////
//   Author: Chris Sergent
//   Date:   May 1, 2012
//   Application: SOA
// Address Points - Layer 0
// Bike Paths - Red Line - Layer 1
// Inhome Daycares - Dark Blue - Layer 2
// Daycare Facilities - Light Blue - Layer 3
// Playgrounds - Purple - Layer 4
// School Property - Green - Layer 5
// Macon Co. Tax Parcels - Layer 6
// Decatur Corporate Boundary - Layer 7
//              DECLARE AND SET VARIABLES BEGIN
//              SET UP DOJO BEGIN
Dojo Framework Require Begin
dojo.require("dojo.parser");
dojo.require("dojo.number");
Parsing dojo.number include four functions
- dojo.number.format() - formats numeric values
- dojo.number.parse() - converts a string to a number
- dojo.number.regexp() - returns a regular expression
- dojo.number.round() - rounds numbers
dojo.require("dojo.data.ItemFileReadStore");
dojo.require("dojo.fx");
dojo.require("dijit.dijit");
dojo.require("dijit.form.Button");
dojo.require("dijit.Toolbar");
dojo.require("dijit.TitlePane");
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("dijit.Editor");
dojo.require("dijit.layout.TabContainer");
dojo.require("dojox.grid.DataGrid");
// Declare Rounding Corners With Rico
var roundCorners = Rico.Corner.round.bind(Rico.Corner);
Dojo Framework Require End
// REST API - Making Tools Available
// ESRI dojo objects
// allows you to work with the dynamic map service resource exposed by the ArcGIS REST API.
// Reference: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/arcgisdynamicmapservicelayer.htm#
dojo.require("esri.layers.agsdynamic"); // dynamic map services generate images on the fly.
dojo.require("esri.layers.agstiled"); // cached map service.
// esri.Map class created a container and required DOM structure for adding
// -layers, graphics, info_window, and other navigation controls
dojo.require("esri.map");
dojo.require("esri.toolbars.navigation");
dojo.require("esri.toolbars.draw");
// ESRI dojo tasks
//  esri.tasks.geometry class represents a geometry service exposed by the ArcGIS REST API.
// Operations include - project, simplify, buffer, and relationships
// Reference: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/geometry.htm#
dojo.require("esri.tasks.geometry");
// Represents a geocode service resource exposed by the ArcGIS REST API.
// It is used to generate candidates for an address.
// It is also used to find an address for a given location.
// Reference: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/locator.htm#
dojo.require("esri.tasks.locator");
// ESRI dojo task for querying against the ArcGIS REST API.
// Reference: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/querytask.htm#
dojo.require("esri.tasks.query");
// ESRI dojo task for identifying against the ArcGIS REST API.
dojo.require("esri.tasks.identify");
// ESRI dojo graphics utility for displaying features in a single layer using the ArcGIS REST API.
// Reference:http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/featurelayer.htm#
dojo.require("esri.layers.FeatureLayer");
ESRI Dojo Objects End
//              SET UP DOJO END
//              DECLARE AND SET VARIABLES END
//          MAP EXTENTS
Set the extent of one map service.
For multiple map services, see the section titled Setting the beginning extent
when using multiple services at-
http://resources.esri.com/help/9.3/arcgisserver/apis/javascript/arcgis/help/jshelp_start.htm
////WARNING WARNING WARNING WARNING WARNING WARNING WARNING WARNING WARNING/////////
//      WARNING WARNING WARNING WARNING WARNING WARNING WARNING WARNING WARNING
//          ENSURE YOU HAVE A GEOMETRY SERVICE CREATED AND RUNNING ON
//          ESRI ArcGIS Server OR YOUR MAP MAY NOT DISPLAY
//          NOTE:   You do not necessarily need to reference the geometry service
//                  in your code.
// Extent and Spatial reference of our map service
//var startExtent = new esri.geometry.Extent({ "xmin": 778733.96207758, "ymin": 1133387.86320644, "xmax": 849794.792685476, "ymax": 1193607.08672764, "spatialReference": { "wkid": 102100} });
// This is the required projection to display in Decatur for imagery
var startExtent = new esri.geometry.Extent({ "xmin": -9907408.2369, "ymin": 4839236.5572, "xmax": -9897146.5658, "ymax": 4847826.1683, "spatialReference": { "wkid": 102100} });
// Sets the extent for the find address query
var addressExtent, newExtent;
// Map Services Begin
// Define Map Section
var gisUrl; // GIS Server Location
// Old Url - http://64.107.106.57/
gisUrl = "http://decgis01/";
var rasSvc; // Raster Service
rasSvc = "Public/Aerial_2012/MapServer";
var mapSvc; // Map Service
mapSvc = "Internal/SOA/MapServer";
var addrLocSvc; // Address Locator Service
addrLocSvc = "Public/WebAddressLocator/GeocodeServer";
var geomSvc; // Geometry Service
geomSvc = "Utilities/Geometry/GeometryServer";
var map, dynamicMapServiceLayer, imageDynamicMapServiceLayer;
dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer(gisUrl + "arcgis/rest/services/" + mapSvc);
dynamicMapServiceLayer.setOpacity(0.4);
//imageDynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer(gisUrl + "arcgis/rest/services/" + rasSvc);
imageDynamicMapServiceLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer");
// http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/arcgisdynamicmapservicelayer.htm#setImageFormat
//imageDynamicMapServiceLayer.setImageFormat("jpg");
// Navigation Tools
var navToolbar;
// Locator service to be used for find address
var locator;
locator = new esri.tasks.Locator(gisUrl + "arcgis/rest/services/" + addrLocSvc);
// SR required for Decatur
var spatialReference = new esri.SpatialReference({ wkid: 102100 });
locator.setOutSpatialReference(spatialReference);
// Geometry Service
var geometryService;
geometryService = new esri.tasks.GeometryService(gisUrl + "arcgis/rest/services/" + geomSvc);
// Map Services End
// ESRI Tasks Begin
// Define Macon County Tax Parcels as Layer to Query
// http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp/intro_querytask.htm#
var queryTask = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/6");
// Creates a new query to be used against the current geometry
var queryParams = new esri.tasks.Query();
var circleSymbol = new esri.symbol.SimpleMarkerSymbol();
circleSymbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE);
circleSymbol.setColor(new dojo.Color([153, 0, 51, 0.75]));
// Declare coordinate for drawing point in find address
var x1, y1;
// Declare geometry for find address
var geom;
// Identify Task
var identifyHandle;
var identifyTask, identifyParams;
// Measure Polyline
var measureLine;
var lineLengthParams = new esri.tasks.LengthsParameters();
var measureLineGraphic;
// Measure Polygon
var measurePolygon;
var polygonLengthParams = new esri.tasks.AreasAndLengthsParameters();
var measurePolygonGraphic;
// Project Point
var pt = null;
var point;
var ptSymbol;
var ptGraphic;
var ptOutSR;
var pointHandle;
var inTown;
// ESRI Tasks End
// Query Layers Begin
// Layers to evaluate if they are in a safe zone based on a sex offender's potential address
var qryBikePaths = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/1")
var qryHomeDayCare = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/2");
var qryDayCare = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/3");
var qryParks = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/4");
var qrySchools = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/5");
var qryDecaturBoundary = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/7");
// Query Layers End
// Graphics Definition Begin
/* Define initial address point to be drawn for find address */
var firstGraphic;
/* Define queried point to be drawn for find address */
var graphicPt;
/* Defines the line drawn for the polygon of the parcel */
var selectParcel;
// Graphics Definition End
//          PAGE INITIALIZATION
function init() {
    // Initialize JavaScript Framework Controls
    // Round Sidebar Corners
    roundSidebarCorners();
    // Add Sidebar
    addSideBar();
    // Add Sidebar Title
    addSideBarTitle();
    // Add Map Navigation Title
    addMapNavigationTitle();
    // Add Map Navigation Content
    addMapNavigationContent();
    // Add Map Tools Title
    addMapToolsTitle();
    // Add Map Tools Content
    addMapToolsContent();
    // Add Address Search Title
    addAddressQueryTitle();
    // Add Address Search Content
    addAddressQueryContent();
    $("sideBarTop").style.cursor = "hand"; // Sidebar Top - To Drag the Sidebar
    $("sideBarTopFill").style.cursor = "hand"; // Sidebar Top Fill - To Drag the Sidebar
    $("sideBarBottom").style.cursor = "hand"; // Sidebar Bottom - To Drag the Sidebar
    $("sideBarBottomFill").style.cursor = "hand"; // Sidebar Bottom Fill - To Drag the Sidebar
    $("dojoGrid").style.display = 'none';
    $("btnClearGraphics").style.display = 'none';
    // Add Footer Section
    addFooterSection();
    addFooter();
    // Enable Sidebar Drag
    EnableDrag();
    // Set Browser to Full Size
    maxBrowserWindow();
    The proxy section is defined on the ESRI sample. I have included it as
    part of the documentation reads that the measuring will not work.
    I thought that might be important.
    // Proxy Definition Begin
    //identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
    //If this null or not available the project and lengths operation will not work.  Otherwise it will do a http post to the proxy.
    esriConfig.defaults.io.proxyUrl = "proxy.ashx";
    esriConfig.defaults.io.alwaysUseProxy = false;
    // Proxy Definition End
    // Programmatically define web services
    // Add controls to the interface
    esriConfig.defaults.map.sliderLabel = null;
    //   Note:
    //          The last layer added to the map is the top layer.
    //          Setting the opacity as shown below allows for hidden
    //          layers to become visible.
    //          LAYERS
    /* Add a dynamic layer */
    All map services use a unique reference to identify the map service
    In ESRI ArcGIS Server, the unique reference is the URL of the published
    map service
    map = new esri.Map("mapSection", { extent: startExtent });
    // Enable identify
    dojo.connect(map, "onLoad", initFunctionality);
    // The dynamic layer is added to the map
    map.addLayer(imageDynamicMapServiceLayer);
    map.addLayer(dynamicMapServiceLayer);
    //alert(dynamicMapServiceLayer.layerInfos[5].name);
    //alert((dynamicMapServiceLayer.visibleLayers.length) + 1);
    // Add toolbar
    navToolbar = new esri.toolbars.Navigation(map);
    // Sets the navigation bar up to handle previous and next extent
    dojo.connect(navToolbar, "onExtentHistoryChange", extentHistoryChangeHandler);
    // Reference - http://forums.arcgis.com/threads/48318-Set-zoomToFullExtent-to-be-my-Initial-Extent
    navToolbar.zoomToFullExtent = function () {
        map.setExtent(startExtent);
    // Add Polygon Tool
    measurePolygon = new esri.toolbars.Draw(map);
    dojo.connect(measurePolygon, "onDrawEnd", function (geometry) {
        removePolygon();
        deactivatePoint();
        // This line of code is a guess
        polygonLengthParams.polygons = [geometry];
        polygonLengthParams.areaUnit = esri.tasks.GeometryService.UNIT_SQUARE_FEET;
        polygonLengthParams.areaUnit = esri.tasks.GeometryService.UNIT_ACRES;
        geometryService.simplify([geometry], function (simplifiedGeometries) {
            polygonLengthParams.polygons = simplifiedGeometries;
            geometryService.areasAndLengths(polygonLengthParams);
        geometryService.lengths(polygonLengthParams);
        measurePolygonGraphic = map.graphics.add(new esri.Graphic(geometry, new esri.symbol.SimpleFillSymbol()));
    // Add Line Tool
    measureLine = new esri.toolbars.Draw(map);
    dojo.connect(measureLine, "onDrawEnd", function (geometry) {
        deactivatePoint();
        removePolygon();
        lineLengthParams.polylines = [geometry];
        lineLengthParams.lengthUnit = esri.tasks.GeometryService.UNIT_FOOT;
        lineLengthParams.geodisc = true;
        geometryService.lengths(lineLengthParams);
        measureLineGraphic = map.graphics.add(new esri.Graphic(geometry, new esri.symbol.SimpleLineSymbol()));
    // Diplay Polygon Area and Distance after measuring
    dojo.connect(geometryService, "onAreasAndLengthsComplete", outputAreaAndLength);
    // Display Line Distance after measuring
    dojo.connect(geometryService, "onLengthsComplete", outputDistance);
    // Make Address Locator Available
    dojo.connect(locator, "onAddressToLocationsComplete", showResults);
    // Connect the row click item to the dojo grid
    dojo.connect(dojoGrid, "onRowClick", onRowClickHandler);
    // Enable tab display for identify
    dojo.connect(map.infoWindow, "onShow", function () {
        dijit.byId("tabs").resize();
Map Tools Begin
// Add history reference for previous and next extent on map toolbar
function extentHistoryChangeHandler() {
    $("btnPrevExtent").disabled = navToolbar.isFirstExtent();
    $("btnNextExtent").disabled = navToolbar.isLastExtent();
Find Address Point Function Begins
function findAddress() {
    if (Page_IsValid) {
        // Clear the map
        map.graphics.clear();
        $("lblResponse").innerHTML = "";
        $("lblAddressStatus").innerHTML = "";
        var add = dojo.byId("txtAddress").value.split(",");
        var address = {
            SingleKey: add[0]
        Locator begins searching for address matches when the method addressToLocations is called.
        The event listener onAddressToLocationsComplete calls the function showResults()
        onAddressToLocationsComplete fires when Locator.addressToLocation() has completed
        locator.addressToLocations(address);
function showResults(candidates) {
    var candidate;
    var symbol = new esri.symbol.SimpleMarkerSymbol();
    var infoTemplate = new esri.InfoTemplate("Location", "Address: ${address}<br />Score: ${score}");
    symbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE);
    symbol.setColor(new dojo.Color([255, 0, 0, 0.75]));
    var points = new esri.geometry.Multipoint(map.spatialReference);
    var incrementor = 0;
    var validRecords = 0;
    var xLoc, yLoc, singleAddress;
    $("dojoGrid").style.display = 'inherit';
    var items = [], obj = {}, loc;
    dojo.forEach(candidates,
  function (candidate) {
     if (candidate.score > 50) {
         obj = {};
         obj['address'] = candidate.address;
         obj['score'] = candidate.score;
         loc = candidate.location;
         obj['x'] = loc.x;
         obj['y'] = loc.y;
         obj['location'] = loc.x + ', ' + loc.y;
         items.push(obj);
    console.log(items);
    // Create data object to be used in store
    var data = {
        items: items
    // Create data store and bind to grid
    store = new dojo.data.ItemFileReadStore({ data: data });
    var grid = new dojox.grid.DataGrid;
    grid = dijit.byId('dojoGrid');
    grid.setStore(store);
    // Evaluate number of addresses returned
    // if there is only one address, set the height of the grid to 0
    if (items.length == 1) {
        $("dojoGrid").style.height = 0
    else {
        // if there is more than one address set the height 50x the number of items addresses returned
        $("dojoGrid").style.height = 50 * items.length;
    // Evaluate if any candidates exist
    if (candidates.length == 0) {
        $("lblAddressStatus").innerHTML = "The Address you entered is not recognized. Make sure you entered it correctly.";
        $("lblAddressStatus").className = "warningMessage";
        $("lblResponse").innerHTML = " Your address should be like the example:" +
        "<br> 111 E MAIN ST " +
        "<br> And the format should be:" +
        "<br> Street Address";
        $("lblResponse").className = "warningMessage";
        $("lblBikePath").innerHTML = "";
        $("lblHomeDayCare").innerHTML = "";
        $("lblDayCare").innerHTML = "";
        $("lblParks").innerHTML = "";
        $("lblSchools").innerHTML = "";
        $("lblCityLimits").innerHTML = "";
        navToolbar.zoomToFullExtent();
        // exit code
        return;
    else {
        // Check all candidates for a matching score greater than 50
        for (incrementor; incrementor < candidates.length; incrementor++) {
            candidate = candidates[incrementor];
                var attributes = { address: candidates[incrementor].address, score: candidates[incrementor].score };
                var graphic = new esri.Graphic(candidates[incrementor].location, symbol, attributes, infoTemplate);
                map.graphics.add(graphic);
                map.graphics.add(new esri.Graphic(candidate.location, new esri.symbol.TextSymbol(attributes.address).setOffset(0, 8)));
                points.addPoint(candidate.location);
                validRecords = incrementor + 1;
                xLoc = candidates[incrementor].location.x;
                yLoc = candidates[incrementor].location.y;
                singleAddress = candidates[incrementor].address;
        if (validRecords > 1) {
            $("lblAddressStatus").innerHTML = "Success!";
            $("lblAddressStatus").className = "normalMessage";
            map.setExtent(points.getExtent().expand(3));
            $("btnClearGraphics").style.display = 'inherit';
        else if (validRecords == 0) {
        else if (validRecords == 1) {
            // Coordinates of single address returned
            $("lblAddressStatus").innerHTML = "The Address " + singleAddress + " was found.";
            map.setExtent(points.getExtent());
            x1 = xLoc;
            y1 = yLoc;
            geom = new esri.geometry.Point(x1, y1, new esri.SpatialReference({ wkid: 343 }));
            graphicPt = new esri.Graphic(geom, symbol);
            // Add Point
            map.graphics.add(graphicPt);
            // Initialize Query
            var qry = new esri.tasks.Query();
            qry.returnGeometry = true;
            qry.ourSpatialReference = { "wkid": 102100 };
            qry.geometry = geom;
            // Check if point is in city limits
            qry.spatialRelationship = esri.tasks.Query.SPATIAL_INTERSECTS;
            qryDecaturBoundary.execute(qry, qryDecaturBoundary_complete);
Display Grid Cell That Was Clicked
function onRowClickHandler(evt) {
    // Set X and Y Coordinates
    x1 = dojoGrid.getItem(evt.rowIndex).x;
    y1 = dojoGrid.getItem(evt.rowIndex).y;
    // Declare geometry and assign coordinates
    // http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/point.htm#
    // http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/point.htm#PointConst1
    // Required for Decatur
    geom = new esri.geometry.Point(x1[0], y1[0], new esri.SpatialReference({ wkid: 102100 }));
    graphicPt = new esri.Graphic(geom, circleSymbol);
    // Add Point
    // Initialize Query
// Custom Buffer Sample
// http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples/util_buffergraphic.html#
// http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples/exp_cors_buffer.html
function doBuffer(geometry) {
    // Set up buffer parameters
    var params = new esri.tasks.BufferParameters();
    params.distances = [500];
    params.bufferSpatialReference = new esri.SpatialReference({ wkid: 3435 });
    params.outSpatialReference = map.spatialReference;
    params.unit = esri.tasks.GeometryService.UNIT_FOOT;
    geometryService.simplify([geometry], function (geometries) {
        params.geometries = geometries;
        geometryService.buffer(params, showBuffer);
function showBuffer(bufferedGeometries) {
    var symbol = new esri.symbol.SimpleFillSymbol(
                esri.symbol.SimpleFillSymbol.STYLE_SOLID,
                    esri.symbol.SimpleLineSymbol.STYLE_SOLID,
                    new dojo.Color([255, 0, 0, 0.65]), 2
                new dojo.Color([255, 0, 0, 0.35])
    var graphic;
    dojo.forEach(bufferedGeometries, function (geometry) {
        graphic = new esri.Graphic(geometry, symbol, { buffer: true });
        // Add point
        // Add polygon
        map.graphics.add(firstGraphic);
        // Add Buffer
    map.setExtent(bufferedGeometries[0].getExtent().expand(2));
    // evaluate if buffered geometries intersect with safe zones
    queryParams.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
    queryParams.returnGeometry = true;
    queryParams.geometry = graphic.geometry;
    // Evaluate if buffer intersects with bikepaths
    qryBikePaths.execute(queryParams, qryBikePaths_complete);
    // Evaluate if buffer intersects with a daycare
    qryDayCare.execute(queryParams, qryDayCare_complete);
    // Evaluate if buffer intersects with playground equipment
    qryParks.execute(queryParams, qryParks_complete);
    // Evaluate if buffer intersects with a Home Daycare
    qryHomeDayCare.execute(queryParams, qryHomeDayCare_complete);
    // Evaluate if buffer intersects with a school
    qrySchools.execute(queryParams, qrySchools_complete);
// Evaluate if address is in City Limits
function qryDecaturBoundary_complete(featureSets) {
    if (featureSets.features.length > 0) {
        // Initialize Query
        var query = new esri.tasks.Query();
        query.returnGeometry = true;
        // This SR is requirer to draw the parcel polygon
        query.outSpatialReference = { "wkid": 102100 };
        query.geometry = geom;
        // Checks where point intersects with parcel
        query.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
        queryTask.execute(query);
        // Declare the graphic for the polygon
        firstGraphic = null;
        selectParcel = null;
        // +++++Listen for QueryTask onComplete event+++++
        dojo.connect(queryTask, "onComplete", function (graphics) {
            firstGraphic = graphics.features[0];
            selectParcel = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new dojo.Color([98, 194, 204]), 3), new dojo.Color([255, 0, 0, 0]));
            firstGraphic.setSymbol(selectParcel);
            // Add Polygon Graphic On parcel as Selection
            geometry = graphics.features[0].geometry;
            // Buffer polygon
            doBuffer(geometry);
    else {
        $("lblResponse").innerHTML = "It's outside the city.";
    return inTown;
// Evaluate Safe Zones
function qryBikePaths_complete(featureSet) {
    if (featureSet.features.length > 0) {
        $("lblBikePath").innerHTML = "Caution, Bikepath";
        $("lblBikePath").className = "cautionMessage";
    else {
        $("lblBikePath").innerHTML = "Bikepath Safe";
        $("lblBikePath").className = "successMessage";
function qryHomeDayCare_complete(featureSet) {
        $("lblHomeDayCare").innerHTML = "Home Daycare Unsafe";
        $("lblHomeDayCare").className = "warningMessage";
    else {
        $("lblHomeDayCare").innerHTML = "Home Daycare Safe";
        $("lblHomeDayCare").className = "successMessage";
function qryDayCare_complete(featureSet) {
        $("lblDayCare").innerHTML = "Daycare Unsafe";
        $("lblDayCare").className = "warningMessage";
    else {
        $("lblDayCare").innerHTML = "Daycare Safe";
        $("lblDayCare").className = "successMessage";
function qryParks_complete(featureSet) {
        $("lblParks").innerHTML = "Parks Unsafe";
        $("lblParks").className = "warningMessage";
    else {
        $("lblParks").innerHTML = "Parks Safe";
        $("lblParks").className = "successMessage";
function qrySchools_complete(featureSet) {
        $("lblSchools").innerHTML = "Schools Unsafe";
        $("lblSchools").className = "warningMessage";
    else {
        $("lblSchools").innerHTML = "Schools Safe";
        $("lblSchools").className = "successMessage";
function clearResults() {
    $("txtAddress").value = "111 MAIN ST";
function initFunctionality(map) {
    identifyTask = new esri.tasks.IdentifyTask(gisUrl + "arcgis/rest/services/" + mapSvc);
    identifyParams = new esri.tasks.IdentifyParameters();
    identifyParams.tolerance = 3;
    identifyParams.returnGeometry = true;
    identifyParams.layerIds = [0, 1, 2, 3, 4, 5, 6];
    identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
    identifyParams.width = map.width;
    identifyParams.height = map.height;
    map.infoWindow.resize(415, 200);
    map.infoWindow.setContent(dijit.byId("tabs").domNode);
    map.infoWindow.setTitle("Identify Results");
function doIdentify(evt) {
    identifyParams.geometry = evt.mapPoint;
    identifyParams.mapExtent = map.extent;
    identifyTask.execute(identifyParams, function (idResults) { addToMap(idResults, evt); });
function addToMap(idResults, evt) {
    addressResults = { displayFieldName: null, features: [] }; // 0
    inHomeDayCareResults = { displayFieldName: null, features: [] }; //2
    dayCareFacilitiesResults = { displayFieldName: null, features: [] }; //3
    playgroundResults = { displayFieldName: null, features: [] }; //4
    schoolPropertyResults = { displayFieldName: null, features: [] }; //5
    maconTaxParcelResults = { displayFieldName: null, features: [] }; // 6
    // evaluate for layers 0,1, 3, 4, 5, and 6
    for (var i = 0, il = idResults.length; i < il; i++) {
        var idResult = idResults[i];
        if (idResult.layerId === 0) {
            if (!addressResults.displayFieldName) { addressResults.displayFieldName = idResult.displayFieldName };
            addressResults.features.push(idResult.feature);
            dijit.byId("safeZoneTab").setContent(layerTabContent(addressResults, "addressResults"));
            i = idResults.length + 1;
        else if (idResult.layerId === 2) {
            if (!inHomeDayCareResults.displayFieldName) { inHomeDayCareResults.displayFieldName = idResult.displayFieldName };
            inHomeDayCareResults.features.push(idResult.feature);
            dijit.byId("safeZoneTab").setContent(layerTabContent(inHomeDayCareResults, "inHomeDayCareResults"));
        else if (idResult.layerId === 3) {
            if (!dayCareFacilitiesResults.displayFieldName) { dayCareFacilitiesResults.displayFieldName = idResult.displayFieldName };
            dayCareFacilitiesResults.features.push(idResult.feature);
            dijit.byId("safeZoneTab").setContent(layerTabContent(dayCareFacilitiesResults, "dayCareFacilitiesResults"));
        else if (idResult.layerId === 4) {
            if (!playgroundResults.displayFieldName) { playgroundResults.displayFieldName = idResult.displayFieldName };
            playgroundResults.features.push(idResult.feature);
            dijit.byId("safeZoneTab").setContent(layerTabContent(playgroundResults, "playgroundResults"));
        else if (idResult.layerId === 5) {
            if (!schoolPropertyResults.displayFieldName) { schoolPropertyResults.displayFieldName = idResult.displayFieldName };
            schoolPropertyResults.features.push(idResult.feature);
            dijit.byId("safeZoneTab").setContent(layerTabContent(schoolPropertyResults, "schoolPropertyResults"));
        else if (idResult.layerId === 6) {
            if (!maconTaxParcelResults.displayFieldName) { maconTaxParcelResults.displayFieldName = idResult.displayFieldName };
            maconTaxParcelResults.features.push(idResult.feature);
            dijit.byId("safeZoneTab").setContent(layerTabContent(maconTaxParcelResults, "maconTaxParcelResults"));
        map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
function layerTabContent(layerResults, layerName) {
    var content = "";
    switch (layerName) {
        case "addressResults":
            content = "<i>Total features returned: " + layerResults.features.length + "</i>";
            content += "<table border='1'><tr><th>Address</th><th>PIN</th></tr>";
            for (var i = 0, il = layerResults.features.length; i < il; i++) {
                content += "<tr><td>" + layerResults.features[i].attributes['ADDRESS'] + " </td>";
                content += "<td>" + layerResults.features[i].attributes['PIN_NUM'] + "</td>";
            content += "</tr></table>";
            break;
        case "inHomeDayCareResults":
            content += "<table border='1'><tr><th>Description</th><th>Address</th></tr>";
                content += "<tr><td>" + layerResults.features[i].attributes['USAGE_DESC'] + " </td>";
                content += "<td>" + layerResults.features[i].attributes['ADDRESS'] + "</td>";
            break;
        case "dayCareFacilitiesResults":
            content += "<table border='1'><tr><th>Description</th><th>Name</th></tr>";
                content += "<tr><td>Daycare Facilities</td>";
                content += "<td>" + layerResults.features[i].attributes['SCHOOL_NAM'] + "</td>";
            break;
        case "playgroundResults":
                content += "<tr><td>Playgrounds</td>";
                content += "<td>" + layerResults.features[i].attributes['PARKNAME'] + " </td>";
            break;
        case "schoolPropertyResults":
                content += "<tr><td>School Property</td>";
            break;
        case "maconTaxParcelResults":
            content += "<table border='1'><tr><th>Name</th><th>Address</th></tr>";
                content += "<tr><td>" + layerResults.features[i].attributes['PRIMARYNAME'] + " </td>";
                content += "<td>" + layerResults.features[i].attributes['SITEADDRESS'] + " </td>";
            content += "</tr></table";
            break;
    return content;
function runIdentify() {
    measureLine.deactivate();
    removePolygon();
    removePolyline();
    measurePolygon.deactivate();
    identifyHandle = dojo.connect(map, "onClick", doIdentify);
    identifyHandle;
function outputDistance(result) {
    dojo.byId("lblDistance").innerHTML = "  " + dojo.number.format(result.lengths[0]) + " feet";
function outputAreaAndLength(result) {
    console.log(dojo.toJson(result));
    dojo.byId("lblDistance").innerHTML = "  " + dojo.number.format(result.areas[0]) + " sq. feet";
function removePolyline() {
    // Remove line graphics
    map.graphics.remove(measureLineGraphic);
    // Deactivate measure line
    // Remove point
    map.graphics.remove(ptGraphic);
    // Deactivate pointhttp://maps.decaturil.gov/ArcGIS/rest/services/InternalMapSampleServiceTest/MapServer/2 or the current URL
    dojo.disconnect(pointHandle);
function removeMeasureTools() {
    // Remove point
    // Deactivate point
    // Remove polygon
    map.graphics.remove(measurePolygonGraphic);
    // Deactivate polygon
// Deactivates Navtoolbar and Identify
function deactivateNavToolbar() {
    // Deactivate Toolbar
    navToolbar.deactivate();
    // Deactivate Identify
    dojo.disconnect(identifyHandle);
// Deactivates Identify
function deactivateIdentify() {
    // Disables identify
function projectPoint() {
    // Remove the line graphics
    // Remove polygon graphics
    // Deactivate the nav toolbar
    // Deactivate identify
    deactivateIdentify();
    // Wire up the point handle to run the projectToWebMercator
    pointHandle = dojo.connect(map, "onClick", projectToWebMercator);
    pointHandle;
function projectToWebMercator(evt) {
    point = evt.mapPoint;
    ptSymbol = new esri.symbol.SimpleMarkerSymbol().setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE);
    ptGraphic = new esri.Graphic(point, ptSymbol);
    ptOutSR = new esri.SpatialReference({ wkid: 102100 });
    map.graphics.add(ptGraphic);
    geometryService.project([point], ptOutSR, function (projectedPoints) {
        point = projectedPoints[0];
        dojo.byId("lblDistance").innerHTML = "  x:" + dojo.number.format(point.x) + ", y:" + dojo.number.format(point.y);
    // Disconnect point handle
function clearPointAndPolygon() {
    removePoint();
    removePolygon();
function clearPointAndLine() {
    removePoint();
    removePolyline();
function removePoint() {
function removePolygon() {
function deactivatePoint() {
function printMap() {
    alert("Print Map");
function getHelp() {
    alert("Help Me");
Map Tools End
// Rico Functions
function roundSidebarCorners() {
    roundCorners('sideBarTop',
                        corners: "top",
                        color: "#E1EBFB"
    roundCorners('sideBarBottom',
                        corners: "bottom",
                        color: "#E1EBFB"
// Dojo Function
// Add Sidebar
function addSideBar() {
    var sideBarConfig = new dijit.layout.BorderContainer({
        $("sideBar")
function addSideBarTitle() {
    var sideBarTitleConfig = new dijit.TitlePane({
        title: "SOA Tools"
        $("sideBarTitle")
// Add Map Navigation title
function addMapNavigationTitle() {
    var mapNavigationTitleConfig = new dijit.TitlePane({
        title: "Navigation", open: true
            $("mapNavigationTitle")
function addMapNavigationContent() {
    var mapNavigationContentConfig = new dijit.layout.ContentPane({
        $("mapNavigationContent")
function addMapToolsTitle() {
    var mapToolsTitleConfig = new dijit.TitlePane({
        title: "Map Tools", open: false
            $("mapToolsTitle")
function addMapToolsContent() {
    var mapToolsContentConfig = new dijit.layout.ContentPane({
        $("mapToolsContent")
// Add Address Query Title
function addAddressQueryTitle() {
    var addressQueryTitleConfig = new dijit.TitlePane({
        title: "Address Search", open: true
        $("queryAddressTitle")
// Add Query Address Content
function addAddressQueryContent() {
    var addressQueryContentConfig = new dijit.layout.ContentPane({
    $("queryAddress")
function addFooterSection() {
    var footerSection = new dijit.TitlePane({
        title: "Ask For Assistance", open: false
            $("footerTitle")
// Add Footer
function addFooter() {
    var pageFooter = new dijit.layout.ContentPane({
        $("footer")
// Scriptaculous Functions
function EnableDrag() {
    new Draggable($("sideBar"));
//Maximize Browser Window Begin
// Reference - http://www.javascriptfreecode.com/53.htm
function maxBrowserWindow() {
    top.window.moveTo(0, 0);
    if (document.all) {
        top.window.resizeTo(screen.availWidth, screen.availHeight);
    else if (document.layers || document.getElementById) {
        if (top.window.outerHeight < screen.availHeight || top.window.outerWidth < screen.availWidth) {
            top.window.outerHeight = screen.availHeight;
            top.window.outerWidth = screen.availWidth;
// Maximize Browser Window End
// Initialize Page
dojo.addOnLoad(init);@
Outcomes
