Find Task
2479
09-11-2014 06:53 AM
HabG_
Hi
I want to use a FindTask to select a feature (polygon or point) using an ID field and zoom to the feature being searched when I click on the search button. This sample on ArcGIS API for JavaScript Sandbox  does it but I don't want the table show below the map. I only want to show the search on the top and the map. Can anyone help please by modifying the the code?
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Display Find Task results in Dojo DataGrid</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dojox/grid/resources/Grid.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dojox/grid/resources/claroGrid.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
    </style>
    <script src="http://js.arcgis.com/3.10/"></script>
    <script>
      require([
        "esri/map",
        "esri/tasks/FindTask",
        "esri/tasks/FindParameters",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/Color",
        "dojo/on",
        "dojo/dom",
        "dijit/registry",
        "dojo/_base/array",
        "dojo/_base/connect",
        "dojox/grid/DataGrid",
        "dojo/data/ItemFileReadStore",
        "dijit/form/Button",
        "dojo/parser",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "dojo/domReady!"
      ], function(
        Map, FindTask, FindParameters, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol,
        Color, on, dom, registry, arrayUtils, connect, DataGrid, ItemFileReadStore, Button, parser
        var findTask, findParams;
        var map, center, zoom;
        var grid, store;
        parser.parse();
        registry.byId("search").on("click", doFind);
        center = [-83.266, 42.568];
        zoom = 11;
        map = new esri.Map("map", {
          basemap: "streets",
          center: center,
          zoom: zoom
        //Create Find Task using the URL of the map service to search
        findTask = new FindTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/TaxParcelQuery/MapServer/");
        map.on("load", function () {
          //Create the find parameters
          findParams = new FindParameters();
          findParams.returnGeometry = true;
          findParams.layerIds = [0];
          findParams.searchFields = ["OWNERNME1", "OWNERNME2"];
          findParams.outSpatialReference = map.spatialReference;
          console.log("find sr: ", findParams.outSpatialReference);
        function doFind() {
          //Set the search text to the value in the box
          findParams.searchText = dom.byId("ownerName").value;
          findTask.execute(findParams, showResults);
        function showResults(results) {
          //This function works with an array of FindResult that the task returns
          map.graphics.clear();
          var symbol = new SimpleFillSymbol(
            SimpleFillSymbol.STYLE_SOLID,
            new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([98, 194, 204]), 2),
            new Color([98, 194, 204, 0.5])
          //create array of attributes
          var items = arrayUtils.map(results, function (result) {
            var graphic = result.feature;
            graphic.setSymbol(symbol);
            map.graphics.add(graphic);
            return result.feature.attributes;
          //Create data object to be used in store
          var data = {
            identifier : "PARCELID", //This field needs to have unique values
            label : "PARCELID", //Name field for display. Not pertinent to a grid but may be used elsewhere.
            items : items
          //Create data store and bind to grid.
          store = new ItemFileReadStore({
            data : data
          var grid = registry.byId("grid");
          grid.setStore(store);
          grid.on("rowclick", onRowClickHandler);
          //Zoom back to the initial map extent
          map.centerAndZoom(center, zoom);
        //Zoom to the parcel when the user clicks a row
        function onRowClickHandler(evt) {
          var clickedTaxLotId = evt.grid.getItem(evt.rowIndex).PARCELID;
          var selectedTaxLot = arrayUtils.filter(map.graphics.graphics, function (graphic) {
            return ((graphic.attributes) && graphic.attributes.PARCELID === clickedTaxLotId);
          if ( selectedTaxLot.length ) {
            map.setExtent(selectedTaxLot[0].geometry.getExtent(), true);
    </script>
  </head>
  <body class="claro">
  <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'"  style="width:100%;height:100%;margin:0;">
    <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="height:40px;">
      Owner name: <input type="text" id="ownerName" size="60" value="Katz" />
          <button id="search" data-dojo-type="dijit.form.Button" type="button" data-dojo-attach-point="button" >Search
          </button>
    </div>
    <div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit/layout/ContentPane" style="border:1px solid #000;"></div>
    <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom'" style="height:150px;">
     <table data-dojo-type="dojox/grid/DataGrid" data-dojo-id="grid"  id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'">
      <thead>
        <tr>
          <th field="PARCELID">Parcel ID</th>
          <th field="OWNERNME1" >Owner 1</th>
          <th field="OWNERNME2">Owner 2</th>
          <th field="RESYRBLT ">Year Built</th>
          <th field="SITEADDRESS" width="100%">Address</th>
        </tr>
      </thead>
    </table>
    </div>
  </div>
  </body>
</html>
RobertScheitlin__GISP
So here is my version with the unneeded requires and functions removed and it zooms to all the returned features:
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
    </style>
    <script>
      require([
        "esri/map",
        "esri/Color",
        "dojo/on",
        "dojo/dom",
        "dijit/registry",
        "dojo/_base/array",
        "dojo/parser",
        "esri/graphicsUtils",
        "dojo/domReady!"
      ], function(
        Color, on, dom, registry, arrayUtils, connect, Button, parser, graphicsUtils
        parser.parse();
        zoom = 11;
          basemap: "streets",
          center: center,
          zoom: zoom
        function doFind() {
            new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 2),
            new Color([255, 0, 0, 0.5])
            return result.feature;
          var myFeatureExtent = graphicsUtils.graphicsExtent(items);
          map.setExtent(myFeatureExtent, true);
    </script>
  </head>
          </button>
    </div>
  </div>
  </body>
</html>
JakeSkinner
Esri Esteemed Contributor
Hi Hab,
Below is an example on how to do this.  The app will zoom to the first result found from the FindTask.
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
    </style>
    <script>
      require([
        "esri/map",
        "esri/Color",
        "dojo/on",
        "dojo/dom",
        "dijit/registry",
        "dojo/_base/array",
        "dojo/parser",
        "dojo/domReady!"
      ], function(
        var grid, store;
        parser.parse();
        zoom = 11;
          basemap: "streets",
          center: center,
          zoom: zoom
        function doFind() {
          var graphic = results[0].feature;
          map.setExtent(map.graphics.graphics[0].geometry.getExtent(), true);
    </script>
  </head>
          </button>
    </div>
  </div>
  </body>
</html>
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
    </style>
    <script>
      require([
        "esri/map",
        "esri/Color",
        "dojo/on",
        "dojo/dom",
        "dijit/registry",
        "dojo/_base/array",
        "dojo/parser",
        "dojo/domReady!"
      ], function(
        parser.parse();
        zoom = 11;
          basemap: "streets",
          center: center,
          zoom: zoom
        function doFind() {
    </script>
  </head>
          </button>
    </div>
  </div>
  </body>
</html>
HabG_
Thanks Jake and Robert, both codes can do the job, however the correct answer choice accepts only one answer.
PatrickWild
Thanks for this useful bit of code, I have integrated successfully in my app.
However, rather than using a content pane, I would prefer a cleaner look and feel.
I would like to use something like the geocoder search box seen here: ArcGIS API for JavaScript | Simple Geocoding
Is this possible?
Any direction appreciated.
PW
