I'm able to get Bing maps to show up in Flex versions of my webmaps, and I can use Bing as a base map in Web AppBuilder apps, but I haven't figured out anyway to add the Bing map collection to the basemap gallery wideget. Any suggestions?
Cheers,
Adam
I'm assuming you are wanting to add the bing basemaps to your ArcGIS Online (AGOL) Basemap gallery? Typically for this I would create an ArcGIS Online map and add the Bing layer as the base map, then save the map to my custom basemap gallery group. I went to test this last night to give more details, but I'm wondering if there is currently an issue with ArcGIS Online and Bing map services. Like you, I'm able to access thru Desktop with my Bing key. I also have the Bing key entered in my AGOL enterprise account, but following the steps to add the Bing base doesn't give any error, but the basemap is blank.
I tested that it was still available thru desktop (to verify my Bing Key was still valid) so I'm now thinking it is a current issue with just AGOL. ??
As to how to reference it directly in code, I do not know how to do that (but would like to know if it's possible).
