I am trying to create a hot spot analysis from points that I generate through the Integrate and Collect Events functions.
However before I get to those steps I am unable to solve an issue. Most of my points have a count field associated with a wide range of values. When I run the Integrate and Collect Events functions I have not found a way of incorporating the count field.
Therefore I thought I would create multiple stacked points based on the count field but have not found a tool for this.
Is there a process to create multiple stacked points based on the count field in the table? Or is there another work around situation?
Any insight would be appreciated.
Many thanks,
DK
Hi David,
Have a look at this discussion. I have posted a script which does exactly what you are looking for.
Duplicate points in a feature class based on count field
