�??Create replica�?� fails with �??000582 : Error occurred during execution�?�,
6663
5
06-02-2013 08:11 AM
JamalNUMAN
Legendary Contributor
I tried to create replica from N arcsde geodatabase to NR file geodatabase but got the error below
[ATTACH=CONFIG]24905[/ATTACH], [ATTACH=CONFIG]24906[/ATTACH]
What might be the issue here?
The feature class is registered and the global ID are added
[ATTACH=CONFIG]24907[/ATTACH], [ATTACH=CONFIG]24908[/ATTACH]
Thank you
Best
Jamal
Jamal Numan
SivaVysyaraju
Hi Jamal,
I have the same issue, did you find any resolution for this? could you please reply?
Thanks & Regards,
Siva P Vysyaraju
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Hi Jamal,
Thanks & Regards,
Siva P Vysyaraju
Hi Siva,
I had this problem but now it works fine with me. Not sure what is the cause of this very frustrating issue.
Best
Jamal
MarcoBoeringa
MVP Regular Contributor
Hi Siva,
Best
Jamal
If you want to find out a little bit more about a possible cause of a specific geoprocessing error (in this case with errorno. 000582), than there is a less known section of the ArcGIS Help, that gives more background about each error-code, and may help in solving the issue:
Understanding geoprocessing tool errors and warnings
For this specific error, look here:
000582 : Error occurred during execution.
In this case, it seems a rather in-specific error, still, checking the tools parameters and settings, might be in order...
by Anonymous User
Not applicable
Many thanks Marco for the contribution
Best
Jamal
MarcelBeckmann
New Contributor III
Had the same problem.
The problem in my Case was, that I had already created a replica with this feature class in the given Geodatabase. After deleting the feature class in the GDB or creating new GDB, the replication worked.
