AnsweredAssumed Answered
Issue on Generating Points Shapefile From An Excel File with X Y Values
Question asked by geonetadmin on Dec 29, 2013
Latest reply on Dec 29, 2013 by geonetadmin
Original User: BEHSEINI
Using ArcGIS 10.2, I have an Excel file (Please review attached zipped Excel file) which I am able to Generate Points by using the "Add XY Data". As I said Points generated on the Map (with Pre-defined Geographic Coordinate System WGS84).I am also able to to Export Points to Shapefile from Data-->Export Data and Add the new generated shapefile into Current document. After this issues starts As:
1- I can not Select Any Point data from graphic Selection By Location, Clicks on table orr Selection by Attributes and ArcMap crashes after any type of Selection happens
2- After closing the map I am not able to add the new generated point shapefile into any map! it take several minutes and finally ArcMap displat this error!
[ATTACH=CONFIG]30138[/ATTACH]
Can you please help me to fix this issue! I went all trough to fix it but didn't work!
Thansk
Outcomes
